New to TalkTalk and connection unreliable
prchew
Message 16 of 16
I am hoping you can help.
I move to TalkTalk approx 3-4 weeks ago from Virgin and I really disappointed with the reliability of the connection.  I am working from home full time at the moment spending most of the day on MS Team calls and I have had so many issues of poor audio and dropped calls, this never used to happen with Virgin and it doesn't happen to my colleagues.  I should also add I am hardwired to the router so it isn't a wifi issue.
Is TalkTalk generally just unreliable or is there a problem with my connection?
Paul
15 REPLIES 15
Message 1 of 16
Don't worry about this.  I explained the (well know) issue clearly and I have served notice under my 30 day great connection guarantee and I am moving supplier.
Paul
Message 2 of 16
Hi prchew,
Thanks for running the speed test, the speed is a bit low in comparison to sync speed. Line test is showing some disconnections on the 14th, 15th and 19th, do you remember if your rebooted the router on these days?
How many telephone sockets do you have? Do you have anything connected to your telephone socket(s) in addition to your router?
Does your master socket have a Test Socket?
Your upstream speed isn't great, unfortunately it may just be that there isn't enough upstream bandwidth for your requirements
Message 3 of 16
@Chris-TalkTalk
As requested I have ran a talktalk speed test, this as expected gave me acceptable results (13 mbs) and I then tried to upload a file and run the speed test again but as explained I lose the internet across all devices for approx 5 minutes and I am then of course unable to access the page to run it again.  I tried this at around 6.50pm and finally managed to post this at around 7.30pm if you want to check logs.  I can still access the router admin page proving their is no issue with my local connection to the router.  I tried to attach some screenshots to this post but this also causes the same issue so I can't post them.
This behaviour is explained perfectly in the thread I highlighted in my earlier post and appears to be a known issue with the type of router.
Can you please call me if you would like any additional diagnostics as I need to get this resolved.
Message 4 of 16
@Chris-TalkTalk
I can do but as I have said my problem isn't due to connection speeds, it is about the reliability of the connection and the issue of a dropped connection when uploading large files.  This is critical to me as I spend most of every day on video conferencing calls so even a drop out for a short period causes the call to degrade and be dropped.  I will do as you ask but I am nearing my 30 day cancellation period, can you extend this while investigating?
Message 5 of 16
Thanks for the information, can you run 3 speed tests at different times of day on the My Account speed checker on a device connected by Ethernet cable to your router (can you try to make sure that no other devices/applications accessing the internet at the time)
https://myaccount.talktalk.co.uk/speed-checker/
Message 6 of 16
@Chris-TalkTalk
No there are many devices connected spread across a family of 4 people all with phones, tablets, windows PC and a couple of Macs.  They are also connected in different ways with my PCs hardwired and the rest spread across 2.4 and 5g connections.
Message 7 of 16
OK thanks, was just one device connected to the internet when you experienced the freezing, or were other devices connected at the time?
Message 8 of 16
@Chris-TalkTalk
No phone line seems fine. Had issues this morning with freezing and lost pings.
Message 9 of 16
Thanks Paul, are you experiencing any problems with your telephone service, any noise on the line?
Message 10 of 16
Hi @Chris-TalkTalk,
The same I am afraid.  While watching a film over the weekend there were several times when the connection went on a go slow introducing buffering for a minute or two before resuming.  My son is also banned from uploading to YouTube as this takes the connection offline for a couple of mins every time.
I have no doubt today that I will have problems with my MS Teams meetings as I do everyday and I suspect this may due to the use of video on the upload.
Paul
Message 11 of 16
Hi Paul,
I'm sorry to hear that you're experiencing problems with your service. How has it been since your last post? Line history is showing that the connection has been stable for the last few days and speed looks OK
Message 12 of 16
Further to this this seems to perfectly describe my problem.
https://community.talktalk.co.uk/t5/Fibre-Broadband/DG8041W-router-disconnection-and-upload-issues-I...
Can you send me a replacement router as specified in that thread? I am also approaching my 30 day guarantee and so I would like this resolved before I lose the option to terminate.  I have also done a test by uploading a video to YouTube and can confirm I lose internet completely for approx. 5 mins.
Thanks in advance for your help.
Paul
Message 13 of 16
Also just tried the service status page and it says:
Your Router
We have not been able to identify your router or its software version
The rest is OK.
Paul
Message 14 of 16
Thanks for your reply, I have updated my profile now.
I don't think the router drops the connection completely but instead pings seems to increase to 1s+ and the call gets dropped.  This only seems to last for about 20-30 seconds when I can reconnect but it happens multiple times a day.
Paul
Skynet_TX
Message 15 of 16
Hi @prchew ,
Have you noticed if the router is actually dropping its connection to the internet, or is it remaining connected but just not giving you the speeds you expect.
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
If you run a speed test does this give you the sort of speeds you expect based on the expected speeds TalkTalk would have quoted to you for your line ?
Then they will hopefully be able to respond to this post within a day or two.
