No broadband
cooper71
Message 15 of 15
Getting pretty fed up of having no internet now, post code RH2 0RX could you please advise when internet service will be back up and running, seriously considering not paying our bill as your not providing the service advertised
14 REPLIES 14
Message 1 of 15
Hi cooper71
I've checked the connection stats and your line is showing in sync at 15.8mb. The connection also appears to be stable.
DLM should start to increase the speed. Please can you leave the router switched on without rebooting and we can check the connection stats again in 48hrs to see if DLM has made any changes to the speed/profile.
Message 2 of 15
@Chris-TalkTalk @Debbie-TalkTalk
Update, my apologies since the phone line being down we have discovered our cats had chewed through the cable from the master socket, we are now installed a new cable and broadband and phone line is back up and running, we are still however experiencing stability issues on the broadband and very slow line speeds of 1.8mbps
Message 3 of 15
Also completely no broadband now for a quite a few days, need to access work emails, it is quite a frustrating issue that it is affecting my work
Message 4 of 15
Update the phone line is no longer working now, home phone won't ring out and you can no longer call the home phone from a mobile, when calling from the home phone it just won't dial and you don't here the dialing tones
Message 5 of 15
@Chris-TalkTalk Yes just the one socket, and all you said is correct
Message 6 of 15
Hi cooper71,
Thanks for the photos, do you just have the one telephone socket in your home? In the bottom photo of the master socket, is that a micro-filter? Is the cable coming out of the bottom of the micro-filter the ADSL cable to your router?
Message 7 of 15
@Debbie-TalkTalk hello, please see attached photos
Message 8 of 15
Hi cooper71
Thanks for your reply. Would it be possible to post a photo of your master socket and how the router is set up at the moment? (post the photo on this thread)
Message 9 of 15
@Debbie-TalkTalk
Also we bought a tp link modem router (archer VR400)
to see if it was the talktalk modem router that had a fault plugged it in with the DSL cable everything wired correctly and would detect the DSL cable and it set up a wifi network but could not connect to the internet, so am sending that modem router back to get a refund, only the talktalk modem seems to be able to astablish a connection to the broadband as said before though still very slow at the 1.5mbps, what is very weird is that my in-laws live 5mins down the road and they are with talktalk same contract as us and there broadband is absolutely fine and running at 30mbps and higher at times, when I carried out a speed check on there broadband they seem to be connecting to a different server than us we connect to Mauritius Telecom Ltd London and they connect to Structured Communications London
Message 10 of 15
Message 11 of 15
Good afternoon @Debbie-TalkTalk
In answer to your test socket question, all I no is it was plugged in and set up by the engineer from talktalk, after having a look we have a single phone line coming in by our front door which is where it's plugged in now and was plugged in there by the engineer, we have had no issues with the internet for best part of a year, and then about a month ago broadband speed plummeted from 30mbps average to 1.5mbps average and connection drops out for days at a time coming on for 20mins here and there then a couple says ago I figured out if you ring out or to the house landline twice letting it ring the router goes from flashing orange to orange and white to then connect with a constant white, so now every time the connection drops out and flashes orange I have to ring the house phone twice then within 10mins the broadband is back up and running still at the very slow speed of 1.5mbps average of this rings bells as a common fault or something unique to us please let us no how to proceed
Message 12 of 15
Hi cooper71
I've completed a line test which hasn't detected any faults.
Is the router connected at the test socket at the moment? Which router are you using? (make and model)
Message 13 of 15
You wouldn't pay for an empty plate in a restaurant would you, so why should talk talk charge for a service they are not providing? Please give me a reason?
Gliwmaeden2
Message 14 of 15
@cooper71, don't post any personal information on the open forum pages. For TT staff to identify your account,  please complete your community forum profile details. Go via your avatar/name; settings; launch profile wizard; make sure you put in your landline phone number and a fallback mobile phone number; save any changes.
Keep your Direct Debit in place. Not paying bills just creates debt problems.
Please give staff time to reach your thread and look into this for you. Wait for a reply before posting further, to keep your thread moving forward in the queue.
