No internet after go live date (fibre 35)
JennyHunter
Message 9 of 9
i have had the internet set up, and i was told when the engineers left it should take 20 minutes to turn on, it has been a few hours and the only lights that light up are the power and wireless lights on the router
no internet connection, and the router selfhelp says that the wire isnt connected - despite the fact that it is, its the same setup that i had before i moved, which worked there, but isnt working now despite being moved,
i have had the go live email, so it should be working, but it isnt
what seems to be the problem? how can i fix it?
8 REPLIES 8
Message 1 of 9
Hi Jenny
I've ordered you a replacement router for testing and you should receive this within the next 24-48hrs.
Message 2 of 9
I do not have another router I can test
Message 3 of 9
Hi Jenny
Apologies for this.
Do you have another router that you can test with?
Message 4 of 9
even after doing this, the router still only has the lights for power and wireless
every other light is off, the router still isnt connecting to the internet
Message 5 of 9
Hi Jenny
I've completed a line test which hasn't detected any faults. I have also completed a radius re sync.
Please can you factory reset the router using the pin hole reset for ten seconds and then let us know once the router has been switched back on again.
Message 6 of 9
done, profile updated
Message 7 of 9
Hi JennyHunter
  • Name
  • Telephone number
  • Alternative contact number
Divsec
Message 8 of 9
Hi @JennyHunter are things better now?  have you tried a 30 minute router reboot this often improves things.
Your post has been flagged for assistance and you should hear soon but please remember that the staff here work office hours. In the meantime please check your community profile and add your landline phone number which is used to identify your account.
