No internet connect since 3pm yesterday - Solid Orange Light on Router
riyad
Message 10 of 10
Our fibre internet connection went down yesterday. Landline is still working ok. Router is showing solid orange light. I have conducted all the diagnostic checks.
  • Switched off router for 30 minutes.
  • Swapped microfilter for new one.
  • Swapped router cable.
  • Plugged into master socket.
  • Reset router via pin hole.
The router when switched on flashes orange, then flashes orange and white then goes solid orange.
Can anyone suggest anything to help?
9 REPLIES 9
Message 1 of 10
Hi riyad
That's great, thanks for letting us know.
Message 2 of 10
Hi Chris
Just to let you know that the issue was resolved when we installed the new router. Thanks for your help.
Message 3 of 10
Hi riyad,
I've ordered the router, it should be with you within a couple of working days, please let us know how you get on
Message 4 of 10
Yes, please. That would be much appreciated.
Message 5 of 10
I can send a router to test with while you're waiting for the callback just to make sure.
riyad
Message 6 of 10
Sorry Chris,  I should have given you a update on the router situation.
When I reboot the router -  first it flashes orange (which I understand is normal), the flashes orange and white (which I understand means it is trying establish internet connection) then goes solid orange (where it usually should go solid white).
I contacted support via live chat this morning to request a router, and went through diagnostics. They were unwilling to send out  replacement as from the information I provided the router is not faulty.
The specifically said because my router flashes orange and white before going solid orange, means to them they router is working correctly.
I now have to wait for a case manager to contact me within 5 working days.
Message 7 of 10
I can send another router to test with, would you like me to arrange this?
riyad
Message 8 of 10
Hi Chris
Thanks for your reply. No, I only have the one router haven't been able to test if that's the problem.
Chris-TalkTalk
Message 9 of 10
Hi riyad,
Line tests are passing but I can see that you have no connection, do we have another router that we can test with?
