No internet connection after go live date
Tsukyo
Message 16 of 16
I just been on a call today because my broadband was supposed to be live yesterday, until now I got no connection. I called technical support for assistance; we've done the checks but it seems that it cannot be resolved on her end. So, she is now escalated it to the case manager and I was advised that I have to wait for a maximum of 5 days 'til I could be reached out by them.
Now, my worries is that it will be over 20 days of my supposed "leave without penalty" if I have to wait that long. And I don' t want to pay for something that is not my problem!! I have been very stressed by having no internet and have to waste my time and days waiting for a good connection and now this? I am still hopeful that it can be fixed. But if I am gonna exceed 20 days waiting for a case manager. I will switch to another provider.
15 REPLIES 15
Message 1 of 16
Alright. Thanks again!
Message 2 of 16
The router was already dispatched, but I'll send out a returns bag.
Message 3 of 16
Good day @Karl-TalkTalk
Will it be possible to cancel the new router? I've spoken to the case manager and he managed to booked an engineer to see what's happening in my connection. And it all went well. I have now connected to the internet and there is no fault in the router.
Than k you!!
Message 4 of 16
Gat back to me as soon as the router arrives and is connected and we can take it from there.
Message 5 of 16
Thank you!!
Message 6 of 16
OK, there is a router on the way to you via courier, so we can make sure it's not a fault one, then we can arrange the engineer for you.
Message 7 of 16
I see, that would be very helpful but its unfortunate that my neighbour does not have a landline as well
Message 8 of 16
If you connect the handset to the filter, or simply unplug the filter and plug the phone in, calling 17070 will tell you 2 things. First, you will hear a dial tone, that will let you know the line is 'live'. Second, 17070 is a general test number.  This just calls through to an automated service at the exchange that will just read out your line number to you.  This is useful to check if there is a crossed line etc. Useful to confirm the engineer has connected the line correctly on install.
Message 9 of 16
Hi, I've asked my neighbor he doesn't have any phone handset. And also another question. If i try to ring that number, where do i know that the line is okay? Will it ring through the router haha. Sorry for the silly question.
Message 10 of 16
Yes, every things as it should be.  I've tested the line, looked at all the voltage levels across the line etc, all are fine. Not seeing any issues that could cause this.
I've a router on the way to you just so we can make sure it's not a faulty router.  If at all possible, if you could borrow a phone handset from a friend or neighbour for 2 minutes just to check the line is working, and possibly dial 17070 to check the number assigned, that would really help.
If it's not a router issue, then I will need to get an engineer out asap to look at this for you.
Message 11 of 16
Yes, I only have one router connected in my flat.
Message 12 of 16
Can you confirm you only have the TalkTalk router connected and no other.
Message 13 of 16
Message 14 of 16
Hi @Karl-TalkTalk I currently have my router only. I dont have any phone althou it showing my on my dashboard that I have a landline. But i dont have any physical phone with it. And yes, my router is connected. It s just showing flashing orange light. Please can you help me
Message 15 of 16
Tests are clear and I'm showing a sync speed of 62mb, but the auth logs are showing a possible BT home hub.
Do you currently have the TalkTalk router connected ?
Is there a clear dial tone on the home phone ?
