No internet connection & no landline calls
TSimao
Message 10 of 10
My WiFi keeps disconnecting at least once a day for hours at a time sometimes. It's been off for over an hour now so my kids can't connect with their teachers for online learning. Also my landline has no dial tone so I'm unable to make outgoing calls and I can't receive any calls as it has a constant busy tone.
9 REPLIES 9
Message 1 of 10
Hi TSimao,
The line test is now showing a different fault type so I've logged this out to Openreach as a non-appointed Task. Openreach will investigate over the next 72 hours and may contact you directly
Message 2 of 10
Ok for 'potential' engineer charges if it comes to that & AM is best.
Message 3 of 10
Hi TSimao
Please can you also confirm potential engineer charges and provide your availability for this visit AM and PM?
Engineer charges
Message 4 of 10
Hi TSimao,
Thanks for trying that. The next step will be to arrange an engineer visit, if you'd like us to do this can you confirm:
Message 5 of 10
I just tested the phone in the test socket & there is still no dial tone & still has a busy tone when I called the number.
Message 6 of 10
Hi TSimao,
I'm sorry for the delay and also to hear this. I've run a test on the line now which has detected a loop fault which can sometimes be caused by internal wiring or equipment connected to the line. Does your master socket have a test socket? If it does then could you test the phone at the test socket with all other equipment removed from the line to see if there is a dial tone please?
Message 7 of 10
@TSimao  posts are answered "oldest first", if you keep posting you just knock yourself back in the queue.
Replies can take a day at busy times.
Alternatively call 0345 172 0046 to report your problem.
Message 8 of 10
3 hours, still no WiFi!!
Message 9 of 10
Talk-Talk like to have your profile upto date, things like...
Name
Telephone number
Alternative contact number
Via this link.....
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
NEVER post personal details into these help forums.
Some, hopefully relevant, contact details....
https://community.talktalk.co.uk/t5/Articles/Our-update-on-Coronavirus/ta-p/2468300
I note the in-ability to make calls.
