No internet connection
celestynek
Message 6 of 6
So basically I don't have access to the Internet, I've already report that problem to helpdesk by live chat but I decided to put more details here and some steps that I have made.
I moved to the new location 2 weeks ago and for the 1st week everything was fine until something went wrong last Saturday.
I already set up router to factory settings and noticed that router has some problems with the vlan 36 according to the logs.
10.02.2017 06:13:36
Error
DHCPC
The WAN DHCP client process has failed on Vlan 36
10.02.2017 06:13:21
Info
SYS
Modem login was successful
10.02.2017 06:12:14
Error
DHCPC
10.02.2017 06:10:52
Error
DHCPC
10.02.2017 06:09:30
Error
DHCPC
10.02.2017 06:08:07
Info
XDSL
VDSL connectivity is up port 1
10.02.2017 06:08:07
Info
WIFI
Channel: (44/40) Channel Hopping initiated/Manually initiated
10.02.2017 06:08:07
Info
DHCPC
The WAN DHCP client process has successfully been launched on Vlan 36
10.02.2017 06:08:00
Info
WIFI
Channel: (11/1) Channel Hopping initiated/Manually initiated
01.01.2013 00:00:31
Info
WIFI
Channel: (1/11) Channel Hopping initiated/Manually initiated
01.01.2013 00:00:29
Info
WIFI
Channel: (40/44) Channel Hopping initiated/Manually initiated
01.01.2013 00:00:27
Info
WIFI
Channel: (36/40) Channel Hopping initiated/Manually initiated
01.01.2013 00:00:27
Info
WIFI
WLAN password has been changed (TALKTALK4C03B9).
01.01.2013 00:00:27
Info
WIFI
WiFi security settings have been successfully saved
01.01.2013 00:00:27
Info
WIFI
01.01.2013 00:00:27
Info
WIFI
01.01.2013 00:00:25
Info
UPNP
UPnP functionality has been activated
01.01.2013 00:00:23
Info
LETH
An Ethernet port is now connected (2/100/FULL)
01.01.2013 00:00:19
Info
DHCPS
The LAN DHCP Server is active
01.01.2013 00:00:19
Info
DNS
DNS name resolution is now active
so my router doesn't get ip address from DHCP server
Local IPv4 Address
192.168.1.1
Local Subnet Mask
255.255.255.0
Local Ethernet Mac address
78:65:59:4C:03:B9
Public IPv4 Address
Public Subnet Mask
ipv4Duration
00h02m21s
Default Gateway
Primary DNS Server
SecondaryDNSServer
ipVersion
IPv4/IPv6
NAT
DISABLED
but the telephone line sems to be fine
Line 1
Status
UP
Connection Time
00h15m37s
Link Status
UP
Standard
VDSL2 (G_993_2_ANNEX_ B)
Line Encoding
DMT
Link Encapsulation
ATM (G_992_3_ANNEX_ K_ATM)
Line 1
Downstream
Upstream
Actual Rate [Kbps]
39970
9995
Maximum Rate [Kbps]
66037
9995
Noise Margin [dB]
13.70
13.40
Attenuation [dB]
11.50
0.00
Power [dBm]
-6.80
-6.90
I already disconnected my router from power supply few times for over an hour - nothing changed
I also checked 3 filters that I have and every time get the same result.
I also tried connecting my router to the different socket but result every time is the same.
Aby suggestions?
5 REPLIES 5
Message 1 of 6
Hi celestynek
Thanks for keeping us updated. Please let us know if you do experience any further issues.
Debbie 🙂
Message 2 of 6
@Karl-TalkTalk
Thanks for your help and quick response. To make sure I rebooted my router twice yesterday and everything works fine !
Thanks again!
Message 3 of 6
Hi @celestynek
Can you retest and let me know if it is working now.  We are showing an IP has been issued.
Message 4 of 6
Hi celestynek
All the usual line tests are clear, but I'm getting a domain error when checking the authentication of your circuit.
I've passed this to networks to take a look.  I'll let you know as soon as they get back to me.
Message 5 of 6
