No internet for 10 days. Can anyone help?
Turboman
Message 29 of 29
Hi talktalk community!
Internet went off, been waiting 10 days but nothing has happened.
I've reported the fault on website and it finds a fault and says an or engineer will fix but no-one came.  Then fault just disappeared after a few days.   Redid the line test and back in same situation.
Can anyone from talktalk help,. Check the progress of this fault.
Jason
PS I have 2 children waiting not so patiently for an answer.
28 REPLIES 28
Message 21 of 29
Hi Turboman,
I'm sorry this is taking so long to resolve, it's still in hand with Openreach. If you don't hear anything beforehand can you bump the thread in a couple of days and we'll check for further updates
Message 22 of 29
@Turboman Sorry that you are still waiting for a fix, I have re-escalated this for you.
Turboman
Message 23 of 29
It's me again!  Still no internet.  Nearly 3 weeks now. Any updates?
Jason
Message 24 of 29
It is frustrating when the internet goes, we forget how much we actually rely on it these days.
The cable fault will affect a number of customers, so Openreach are working to replace the cable as soon as they can.
Turboman
Message 25 of 29
Ok Karl thanks for letting me know.  It's very frustrating, everything in my home needs the internet.
Jason
Message 26 of 29
Hi Jason,
This is linked to an Outage on the Openreach side.
There is a cable fault and Openreach are working to replace the affected cable. They have arranged for traffic management so they can access the affected cable and have given a target date of 27th Aug and asked us to review the case with them on 28th.
Turboman
Message 27 of 29
I've added my number Karl.
Jason
Message 28 of 29
Hi Jason,
I'll look into this for you asap. Just need you to add the home phone number to your 'Community Profile' so I can locate your line and details.
