No internet, intermittent
KeithWilcox
Message 13 of 13
For several days now we have an intermittent no internet problem. The internet light on the router is green and the computer says ‘internet connection ‘ but cannot connect to anything. The router has been rebooted many times now but the problem remains. Any ideas?
12 REPLIES 12
Message 1 of 13
Message 2 of 13
Hi Chris,
Thank you
Message 3 of 13
Hi Keith,
I've ordered a replacement router, should be with you within a couple of days but please allow up to 5 working days for delivery
Message 4 of 13
Hi Michelle,
Yes, if you think that could be the problem.
Message 5 of 13
Hi Keith,
Ok would you like us to send a replacement router for testing?
Message 6 of 13
Hi Michelle,
No, I only have this router.
Message 7 of 13
Hi Keith,
Ok thanks for confirming this. I've checked and the router currently has the latest version of firmware. Do you have an alternative router that you can test with to rule this out?
Message 8 of 13
Hi  Michelle
The problem happens with wired and wireless. We have had the problem since April 24th. Friday evening was very bad. I have changed the DNS settings of the router to Google as suggested here. But this morning at 07.37 to 07.39 internet was lost on wired and wireless devices. The router internet light was green and windows network indicated internet connection.
Lost connection again at 07.59 to 08.03, this also happened at the exact same time yesterday!
Message 9 of 13
Hi Keith,
I'm sorry to hear this and I'll take a look now. I've run a test on the line which hasn't detected a fault and I can only see 1 re-connection. Just to confirm, does this affect both wired and wireless?
Message 10 of 13
Hi @KeithWilcox
Message 11 of 13
The router is Huawei HG633.
there are no messages.
The internet light is green and Windows network says internet connection but I Cannot connect to any sites.
Message 12 of 13
When you can't get anywhere, do you get any errors that relate to DNS? If so, you could try changing the routers internet configuration to use a different set of DNS servers, like Google's on 8.8.8.8 & 8.8.4.4. If you tell me the make/model of TalkTalk router you have, I should be able to tell you how to do this, if you are not sure.
