No internet
Andrew_Clarke0705
Message 24 of 24
Hi. Lost all internet. Flashing orange. Had hour long chat with support but apparently it may be the exchange. Engineer booked but gonna take ages. Any idea what else I can try.
23 REPLIES 23
Message 1 of 24
Hi Andy
I'm so glad to hear that this fault has been resolved, thanks for letting us know 🙂
Message 2 of 24
So engineer came out and it was a problem with the cable at the top of the pole. They replaced the cable, but had to change the socket location to an outside wall.  The original cable came down the pile, UNDER ny driveway and into the house. No ide who thought burying the cable under a few feet of concrete was a good idea, but fixed now at least. Internet all back up and running now.
thanks for all your help Debbie
cheers
Andy
Message 3 of 24
Hi Andy
No problem. Please let us know how you get on.
Debbie 🙂
Message 4 of 24
Thanks Debbie
Message 5 of 24
Hi Andy
Thanks for confirming your details.
In regards to potential engineer charges, if the fault is found to be with Openreach maintained equipment then no charges would be applied.
I have arranged the engineer visit for 14/05 AM (8am - 1pm)
Message 6 of 24
Hi Andy
Message 7 of 24
Yes please.  Can’t leave it as it is.
thanks for your help
regards
Andy
Message 8 of 24
Morning Andrew
I've completed another line test which is detecting the same fault.
The next step will be to arrange an engineer visit. Would you like me to arrange this?
Message 9 of 24
Hi Andrew
Thank you.
Please can you leave the router, phone and microfilter at the test socket overnight?
I can then run the line test tomorrow morning.
Message 10 of 24
Cool. I will set it up tonight ready for tomorrow
thanks Debbie
Message 11 of 24
Yep, that's the one.  🙂
Message 12 of 24
So straight from the middle plug via filter to the router.
I may have to do this tonight ready for tomorrow as back in meetings and school work revision for GCSEs.
Message 13 of 24
You need to use a plugin microfilter.
Message 14 of 24
Might be a silly question but how? I can take the plate off but no obvious plug socket except the one in the middle.
thanks
Andy
Message 15 of 24
Hi Andy
If you could connect at the test socket that would be great, I can then run another line test in this set up.
Message 16 of 24
Hi Debbie
no at the moment it is connected in the normal way. I have a 5C mk4 socket. I can try and connect it to the test socket
thanks
Andy
Message 17 of 24
Hi Andy
I've completed a line test which has detected a fault towards the property and Openreach are requesting that we arrange an engineer visit.
Is the router currently connected at the test socket?
Message 18 of 24
Hi Michelle
just wondered if you could check my line. Speed is down to around 6mbps. Sort of crazy as I sm usually in the 80s
kind regards
Andy
Message 19 of 24
Hi Andrew,
Ok thank you for the update. If the connection does become unstable then please let us know and we can check this for you here.
Message 20 of 24
Thanks Michelle
no idea what the fault is/was. No response from customer service. 🤞though it seems to have stabilised.
thanks
Andy
