No internet
Claireba36
Newbie
Message 3 of 3
Disgusting service by talk talk, router not working showing orange light, talk talk run tests won’t say what the problem is but will get a manger to sort it out in 3 working days!! I have a disabled child who has a camera in their room for safety and now we don’t have this option! As no internet.
Message 1 of 3
Hi Claireba36
I've completed a line test which hasn't detected any faults.
I have also completed a radius re sync. Please can you factory reset the router using the pin hole reset for ten seconds and then post back to let us know when the router is switched back on.
Skynet_TX
Message 2 of 3
Hi @Claireba36,
If you would like the staff here on the community to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they may then be able to check what is happening and get you an update. If you have been told 3 working days then this may be an indication that the fault has to be referred to Openreach, as they often quote a response time of 2 - 3 days for residential broadband faults.
