No internet
Pash02
Super Duper Contributor
Message 9 of 9
WiFi hub showing the white light but I have no internet.
Not the 1st time this has happened.
I have currently turned the hub off for 30 minutes to see if that fixs it again.
I can't find the services status section on the website while using my phone.
Help please
8 REPLIES 8
Message 1 of 9
I'll get a different model hub out to you so we are sure its not a hardware issue and if still failing, this will need an engineer out.
Pash02
Message 2 of 9
IMG_20211116_102656.jpgYes
Message 3 of 9
Hi Pash02
Is the router now at the test socket?
Pash02
Message 4 of 9
Hi ya
I have a constant flashing amber light and not turning white
Message 5 of 9
Hi Pash02
Please can you remove the face plate, there should be 2 small clips either side of the socket.
Can you then connect the router and a filter directly at the test socket?
Pash02
Message 6 of 9
Hi ya
My hub hasn't been replaced since I got it.
I am currently running on data as I cannot get the TT internet.
This is my plug socket
Message 7 of 9
Hi Pash02
I've completed a line test which hasn't detected any faults - Line test is clear.
Is the router at the test socket? Have we recently sent you a replacement router for testing?
Gliwmaeden2
Message 8 of 9
The service centre is listed under "help with your service" and should be accessible on your phone, @Pash02.
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
If you're still not able to use wi-fi, you can access it on mobile data after logging into My Account.
