(OCE) Fast 5364 update request
ravi2011
Message 4 of 4
Could i request an OCE to update my Sagecom router from 2600t to 2816t or newer firmware.
Rav
3 REPLIES 3
Message 1 of 4
Hi Rav
Thank you 🙂
I have now updated your router firmware.
Message 2 of 4
Hi Debbie, I have factory reset the unit
Rav
Message 3 of 4
Hi Rav
I'm unable to connect to your router. Please can you factory reset the router using the pin hole reset for ten seconds, I can then try this again.
