Online checker is wrong
zofbtb
Message 9 of 9
Tried to sign up for TT online putting in my postcode and phone number. It came up with"Service isn't in your area" message.
This was wrong as (1) There's TT LLU in the exchange (2) Neighbours have TT and (3) My old ISP is First Utility who use TT
Ended up signing up just using postcode. I think you should get this fixed.
8 REPLIES 8
Message 1 of 9
@zofbtb
Thanks for flagging this, Ill pass this onto the relevant team for investigation.
Message 2 of 9
Apologies, I didn't realise you meant via TalkTalk's website, I was thinking of the BT/Openreach checker.
zofbtb
Message 3 of 9
Surely there is. I typed my number in and TT's website said erroneously that their services weren't available. Doubly strange as my previous ISP was First Utility who use TT's infrastructure.
Message 4 of 9
There is nothing to fix. Only BT numbers are on their database, other LLU providers need to use the address checker.
zofbtb
Message 5 of 9
Thanks, it is in TT's own interest to sort this out as it immediately turns away potential customers
Message 6 of 9
@zofbtb
Seems not the case as bt opteach  hold the main powers that is why bt and bt opteach have been made to slit.
but i am sure talktalk team will feed it back to someone.
Hope that help Regards Joe
zofbtb
Message 7 of 9
Yes, the number mustn't be in the database. It should be though. Surely the info should be 100% correct for valid UK landline numbers.
hosay299
Message 8 of 9
@zofbtb Welcome to the community.
It could be that ur phone line number is not on the data base but ur postcode is as i have found this on other site which ask the same for me.
If u need any help just post in the correct area on here and the team will help.
just need to finsh of ur profile so thew oce can help.
A bite of info of Forum:
To save yourself time, please make sure that your community profile includes your first & last names, broadband phone number & if possible an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:- Personal Profile > Personal Information
