Openreach modem dsl and internet light keeps turning off
Castle66
Message 4 of 4
I upgrade to fibre150 and the modem keeps dropping connection every hour. Worse in evening. DSL and Internet light on modem turn off regularly. Wifi router works fine. Line test is fine, no problem found. I am working from home and this is not working for me.
Midlands
3 REPLIES 3
Message 1 of 4
Thank you. I've run a test on the line now which is clear, however I can see quite a few re-connections on the line. Can I just confirm, has the set up changed at all since this was installed by the engineer or any new equipment added to the line?
Castle66
Message 2 of 4
Done
Midlands
Message 3 of 4
  • Name
  • Telephone number
  • Alternative contact number
