Orange flashing light on router
Bparker
Message 3 of 3
Tv apps like Netflix and Prime stopped working and can't get onto Internet on laptop. Has been flashing orange at the router continuously. I've turned off and on at plug etc and not working still.
Message 1 of 3
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @Bparker,
A flashing amber light usually means that the router can't detect a broadband signal on the phone line.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
