Orange flashing light sagemcom fast 5364
NoStall_123
Message 6 of 6
Pressed the WPS button on the back of the router to connect TV to it. I now have a flashing orange light instead of a continuous white light. I am still connected to the internet but, the orange light is still flashing - why?
5 REPLIES 5
Message 1 of 6
Hi NoStall_123
That's great, thanks for letting us know 🙂
NoStall_123
Message 2 of 6
Yeah, all working fine, thanks 🙂
Message 3 of 6
Hi NoStall_123
Sorry for the delay.
Is this working ok now?
NoStall_123
Message 4 of 6
Thanks for your reply, the TV was connected OK but the orange light was still flashing so, I rebooted the router by logging on to it - didn’t want to just kill the power. This sorted it! The constant white light was now on. However, I think the router had another issue, it stopped the WiFi signal after about an hour (constant white light on) this happened every time I reset the router. The next day I called TalkTalk and they sorted it - I’m not sure what they did but, firmware update was mentioned.
paulshent
Message 5 of 6
That really is saying it is waiting for the TV to connect.
Is the TV now connected ?
Do all other devices connect ok
Have you tried a power cycle on the modem/router ?
