Own Router - Fibre 150
Tabslash
Message 2 of 2
Good evening all,
I want to understand what settings should I put on my personal router (ASUS RT-AX92U) to go live and use Fibre 150. Please note I’m coming from same G.Fast setup with open reach modem with EE fibre 150 so essentially the setup is ready I’m willing only to understand the settings I should use now.
Many thanks
Don.
1 REPLY 1
Message 1 of 2
When using your own router, you can choose the option if available that your isp does not need a username / password.
We use network authentication so the details are not really required.  Some router models do need a username / password to be entered, in these instances, for the username, just put yourphonenumber@talktalk.net and for the password just use something like 12345678 etc.
