POOR SPEED TO DEVICE
pikaokras
Message 3 of 3
I'm on Fibre 65 package.  The internet speed to router shows good but speed to device show as poor after speed tests. I was on live chat, they reset the router from their end and I cleared cache & cookies from my end, then the chat got terminated.  My wifi signal is poor no matter where I position my router and no matter how many devices are connected.
Any advice on how I can improve my wifi signal would be greatly appreciated.
Chris-TalkTalk
Message 1 of 3
Hi pikaokras,
I can see that Keith has kindly offered to help you with this. If you could update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
We can then take a look at your connection stats. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Message 2 of 3
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
