Packet Loss
Archie Headland
Message 39 of 39
Hi, we are currently experiencing packet loss issues with our Talk Talk WiFi. We've tried packet loss tests on multiple devices with different methods of connection (Ethernet and WiFi), but we still experience from 2-15% packet loss on every test on every device. As I play online games it's very disruptive and causes issues such as rubber banding. Latency is fine around 11ms and download and upload speeds are perfect. The only issue seems to be packet loss. Any help would be appreciated.
AGHeadland
38 REPLIES 38
Message 1 of 39
Hi Archie,
How are you getting on, have or Network Team contacted you?
Message 2 of 39
I would just get off their shoddy network. LEAVE asap Mate
Josh
Message 3 of 39
Hi Archie,
Apologies for the delay, I've asked our network team for an update, I'll let you know when I receive an update
Archie Headland
Message 4 of 39
Is there anyway we can speed this process up, It's been 2 and a half weeks and I've had no improvement. It's really becoming an issue now. Would leaving talk talk fix this packet loss issue? The engineer found no internal issues so I'm certain its nothing to do with my end.
AGHeadland
Message 5 of 39
Hi Archie,
I have been having the EXACT same issue now for 3 weeks. I have had open reach come out twice and change the fibre ports and if you check my profile/latest post you can clearly see NOTHING has been fixed. I strongly suggest you leave Talk Talk. I am leaving as of 30th of July (THANK GOD!!!!) The support team on here have been excellent but unfortuntely talk talk have not. I have had 3 routers sent out too me, two openreach engineers and one talk talk engineer and I am STILL having these issues....If not worse!! Please RUN from talk talk
Josh
Message 6 of 39
Message 7 of 39
Okay thanks
AGHeadland
Message 8 of 39
Hi Archie,
I've asked our network team to take a look at this, we'll let you know when we receive an update or they may contact you directly
Message 9 of 39
Yes I have both Sagemcom hub and the Huawei WiFi hub and tested them both and they both give the same packet loss. There hasn't been any improvements since the DLM was reset.
AGHeadland
Message 10 of 39
Hi Archie Headland
The engineer we arranged was a BB engineer.
Can I just check, have you tested with both the Huawei WIFI hub and Sagemcom hub?
Have there been any improvements at all since the engineer fixed the errors and reset DLM?
Archie Headland
Message 11 of 39
Hi @Debbie-TalkTalk
The engineer came round and unfortunately it didn't help resolve the packet loss. He reset the DLM and that fixed some minor errors that he detected at the master socket. Thought it didn't help fix my packet loss. He said there was an error in the local area that could be affecting us, but its not confirmed. He also recommended asking for a broadband engineer, as he wasn't familiar with what packet loss even was so I'm not sure he really understood what the issue is. Overall, I still need help fixing this packet loss.
AGHeadland
Message 12 of 39
Message 13 of 39
Okay thanks I'll let you know how it goes.
AGHeadland
Message 14 of 39
Hi Archie Headland
Thanks for the Private Message.
I have arranged the Openreach engineer visit for 15/07 PM (1pm - 6pm)
Message 15 of 39
Hi Archie Headland
I can arrange the engineer visit for you.
In regards to potential engineer charges, more information be found here Engineer charges
Message 16 of 39
Hi, @Karl-TalkTalk. Yes I do want to proceed, an engineer would be great. Would it be free to have the engineer come around.
AGHeadland
Message 17 of 39
All tests are clear so nothing obvious stands out.
I've pulled the DLM logs for the last 72hours and these are showing errored seconds at all times (every 15 minutes)
An engineer can be arranged for you, would you like to proceed with this ?
Message 18 of 39
Wired Ping Test:
Ping statistics for 172.217.169.35:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 18ms, Maximum = 20ms, Average = 18ms
Wired Trace Route test:
Tracing route to google.co.uk [172.217.169.35]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms ttrouter.lan [192.168.1.1]
2 10 ms 10 ms 18 ms ae50-ner001.msp.as13285.net [78.144.1.33]
3 11 ms 10 ms 12 ms ae50-scr001-msp.as13285.net [78.144.1.32]
4 * 18 ms 15 ms ae63-scr102.thw.as13285.net [78.144.1.128]
5 16 ms 16 ms 16 ms 74.125.51.110
6 17 ms 16 ms 22 ms 216.239.40.81
7 18 ms 20 ms 17 ms 172.253.66.87
8 16 ms 17 ms 20 ms lhr48s08-in-f3.1e100.net [172.217.169.35] @Michelle-TalkTalk
AGHeadland
Message 19 of 39
Hi Archie,
Thanks. I can't copy your image, would it be possible to post the results as plain text please.
Archie Headland
Message 20 of 39
@Michelle-TalkTalk
Wired ping tests:
Wired trace route test:
AGHeadland
