Packet loss and ping delay since change in weather: DG8041W TalkTalk Wi-Fi Hub Version v1.05t
oldfogie
Whizz Kid
Message 4 of 4
I have built a network monitor that records my service stats by pinging the talktalk server. All has been fine, but since we have had some rain the connection has been dropping out .
The stats shown below show an average packet loss over 5 pings, and an average ping time.
Normally I see a packet loss of zero and a ping time below 20msec.
You can see in the stats below that from 2021/04/27 19:00 my previously stable connection started showing packet loss and jitter.
I've checked the service status and its not showing any issues
https://www.talktalk.co.uk/help/servicestatus/status-check/check
Pinging 107.162.133.62 TalkTalk server
Date, Time; WiFIStatus%; lost, wait;
2021/04/27, 00:00:47; 100; 0.02, 17.77;
2021/04/27, 01:00:48; 100; 0.75, 44.13;
2021/04/27, 02:00:47; 100; 0.63, 40.45;
2021/04/27, 03:00:47; 100; 0.00, 17.32;
2021/04/27, 04:00:47; 100; 0.00, 17.12;
2021/04/27, 05:00:47; 100; 0.00, 17.28;
2021/04/27, 06:00:48; 100; 0.00, 17.22;
2021/04/27, 07:00:48; 100; 0.02, 18.08;
2021/04/27, 08:00:48; 100; 0.00, 17.52;
2021/04/27, 09:00:48; 100; 0.00, 17.73;
2021/04/27, 10:00:48; 100; 0.00, 17.33;
2021/04/27, 11:00:48; 100; 0.02, 18.08;
2021/04/27, 12:00:48; 100; 0.00, 17.60;
2021/04/27, 13:00:48; 100; 0.00, 18.12;
2021/04/27, 14:00:48; 100; 0.00, 18.65;
2021/04/27, 15:00:48; 100; 0.00, 19.50;
2021/04/27, 16:00:48; 100; 0.03, 19.60;
2021/04/27, 17:00:48; 100; 0.00, 18.13;
2021/04/27, 18:00:48; 100; 0.00, 18.10;
2021/04/27, 19:00:48; 98; 0.30, 44.35;
2021/04/27, 20:00:48; 100; 0.40, 66.85;
2021/04/27, 21:00:48; 100; 1.30, 89.50;
2021/04/27, 22:00:48; 100; 1.22, 89.20;
2021/04/27, 23:00:48; 100; 0.57, 75.08;
2021/04/28, 00:00:49; 100; 0.83, 81.57;
2021/04/28, 01:00:48; 100; 0.25, 68.85;
2021/04/28, 02:00:48; 100; 1.03, 84.00;
2021/04/28, 03:00:48; 100; 1.13, 89.50;
2021/04/28, 04:00:48; 100; 0.55, 65.17;
2021/04/28, 05:00:48; 100; 0.20, 53.63;
3 REPLIES 3
Message 1 of 4
Thanks for the update. Can I just confirm, when the connection is dropping does this also happen on a wired device? Do any of the lights change on the router? You've mentioned that it has happened since rain, is there any noise on the line?
Message 2 of 4
Wired connection to the router. The network minitor uses a wifi connection but as you can see from the data its 100% uptime.
Message 3 of 4
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault and the connection looks stable. Just to confirm, are you currently connected wired or wireless?
