Phone line dead but broadband working, though slower than usual
Katy-99
Message 6 of 6
Phone line has been dead for a couple of days, broadband connection working, but often extremely slow. Test shows its not as fast as it should be.
I've been on the chat line today, but got nowhere after 3 quarters of an hour & had to go out.
Hope you can help, thank you.
5 REPLIES 5
Message 1 of 6
Hi Katy-99,
Thanks for the update and I'm glad to hear that the fault has been resolved 🙂
Message 2 of 6
Thank you all for your help.
Open Reach have been and we now have a clear line. Our local telegraph pole has very old and crumbling connections, so we have had several instances in the past few years where changes to other lines has damaged ours. Apparently, at some point the connection block on the pole is going to be changed at some point in the future!
Many thanks for the help on this forum - much better than the chat line!
Best Regards.
Arne-TalkTalk
Message 3 of 6
Hi Katy-99
Line tests have picked up a fault.
We have requested an engineer to go out to the exchange in the next 48 hours.
We can check the fault ticket on Thursday for an update
Arne-TalkTalk
Message 4 of 6
Hi  @Katy-99
Sorry that you are having problems.
I will run some tests and get back to you.
Message 5 of 6
