Phone master socket point not near a power socket
JFBed
Message 7 of 7
Would anyone be able to confirm if I can just get a longer DSL lead so that the hub/router can sit next to a power socket, with the long DSL lead running to the phone master socket? Will this cause any issues, and should TalkTalk supply a longer lead, or should I buy one separately?
Thanks!
6 REPLIES 6
Message 1 of 7
Great, thank you very much for your help @martswain!
Message 2 of 7
Yes, leave the filter where it is and use your new extension cable from there to wherever you have the router.
Message 3 of 7
Thanks @martswain. I only have a master point with one slot, which the filter box is plugged into.
Could I replace the DSL line that runs from the hub/router into the filter box with a longer DSL wire?
That way the filter box would stay at the master point, but the hub/router could be sat nearer a power socket.
Cheers!
Message 4 of 7
If you have a master socket that has two slots, then the required filter is incorporated in that hardware.
Just plug your new extension cable into the DSL slot.
Message 5 of 7
Thanks @martswain
By keeping the filter at the master point, you mean the box that the DSL line runs into, which also has a slot for a phone set to connect to? Could I put a 15m DSL cable into this filter box, so the filter stays at the master point, but the cable can then run up to the hub/router?
Thanks!
martswain
Message 6 of 7
I am running a 15 m DSL extension with no loss of speed.
If you have a Master Socket with only one slot and a dangly microfilter, do not use a normal phone extension, keep the filter at the Master Socket.
TT do not supply cables, you'll need to buy one.
