on 09-03-2021 04:26 PM
Hello.
As per the above title, please can you turn off Cloudcheck (and any other optimisations on this router) so that I have full control over wifi etc.
I have been playing around with modems/routers for many years and like to optimise settings myself. In this instance, I have been trying to set the 5GHz wifi to channel 56 but it keeps resetting to a very crowded 44; this is the difference between 20-30Mbits/s and 10-20Bits/s.
Thanks in advance.
on 17-03-2021 07:40 AM
Hi TariqS
Would you like me to send a different router for testing to see how the connection compares?
on 16-03-2021 09:45 PM
Sorry, Debbie. Just found your message in spam! Dumb Yahoo Mail.
I only have wireless connections; I should really test using a wired one but as it's an unpredictable problem, it would be difficult to capture.
Still... Watch this space! 🤓
on 12-03-2021 07:51 AM
Hi Tariq
Is this only affecting the wireless connection?
on 12-03-2021 01:11 AM
Reporting back...
Speeds are now much better and I don't unexpectedly lose connection from the router switching channels on its own.
Nevertheless, something else seems to be kicking me off the internet periodically and I'm not sure what that is and whether it's an internal or external factor. So still monitoring... 🙁
Tariq
on 11-03-2021 06:08 AM
Hi TariqS
Thank you 🙂
The channels should now remain on the ones you have chosen.
on 10-03-2021 03:00 PM
Thank you kindly, Debbie.
Will tell you how it goes. 😃
Note: it does take a long time, compared to my previous routers, for the Sagem to switch channels and come back online. 🤔
on 10-03-2021 06:27 AM
Hi TariqS
The WIFI optimisation has now been switched off, please let us know how the connection compares.
