Please disable WiFi optimisation on my Sagemcom Fast 5364 (again)
alanl8
Message 6 of 6
Since the firmware on my Sagemcom Fast 5364 was upgraded to SG4K100136, it appears that the WiFi optimisation feature has been re-enabled on my account (this was previously disabled in July 2020) as the automatically selected channels (2.4GHz: 1 and 5GHz: 36) are congested in my location and I need to manually select alternative channels (as per my previous post: https://community.talktalk.co.uk/t5/Fibre/Sagemcom-Fast-5364-channel-hopping/m-p/2595122#M281083)
Since the firmware upgrade, the router keeps resetting back to 1 and 36, with logged messages such as: "Channel: (6/1) Channel Hopping initiated/Manually initiated", usually within a few minutes of me manually setting the WiFi channels.
Please can one of the OCEs disable the WiFi optimisation feature on my account again, to stop the automated channel hopping?
Much appreciated.
5 REPLIES 5
Message 1 of 6
You're Welcome 🙂
alanl8
Message 2 of 6
Hi Karl, just to confirm that the channels haven't changed since I set them yesterday, so it looks like that's resolved the issue.  Thanks again for your help!
Message 3 of 6
No Problem 🙂
alanl8
Message 4 of 6
Thanks Karl!
So far it's stayed with the channels I've manually set, so hopefully that's sorted it but I'll report back after 24 hours, to confirm that it's resolved.
Message 5 of 6
Wifi Optimisation should now be off.
