Please disable WiFi optimisation
akeel
Message 3 of 3
Can you please disable WiFi optimisation on my line as it reverts to a busy channel daily and I am having to manually reset.
This was done previously for me a couple of years ago but seems to have reverted after an update on my router by the looks of it.
Incase this is a different issue the problem I have is I set the WiFi channel to most optimum as WiFi is very congested where I live. How er the channel will change back to a busy channel over night so have to change manually daily.
Akeel
Message 1 of 3
Hi akeel
Apologies for this.
The WIFI optimisation has now been switched off, please let us know if you do experience any further issues.
Skynet_TX
Message 2 of 3
Hi @akeel,
The support team here will be able to disable Wi-Fi Optimisation for you when they return on Monday.
