Please stop changing wireless channel
Cobiee
Message 6 of 6
Hi, I've seen on this forum that talk talk customer's can request that their router "WiFi optimisation" be turned off. I need this doing because all my neighbours are on the same channel and it's affecting my WiFi signal quality as everytime I go into my router settings they're automatically changing back without 24 hours, this is incredibly frustrating, why give me the option to change settings if you're just going to change them back??
AG
5 REPLIES 5
Message 1 of 6
Hi Cobiee,
No problem, please let us know how the connection compares 🙂
Cobiee
Message 2 of 6
Thanks very much all!
AG
Message 3 of 6
Hi Cobiee
The WIFI optimisation has now been switched off. Please let us know how the connection compares.
Gliwmaeden2
Message 4 of 6
Am just escalating this thread into the workflow for you, @Cobiee.
paulshent
Message 5 of 6
Hi.  An OCE will pickup and disable to wifi optimisation from Monday onwards
Just ensure that your profile contains your full name and telephone number otherwise they will be unable to locate your account.
Do not post that information on this thread.
