on 26-10-2020 03:16 PM
Having upgraded from broadband to fibre a few months back, i am finding alot of the time my download speeds are worse than before i upgraded. I live alone, so there isnt ever many devices connected, before i never had any buffering issues etc, but now its a common issue.
Doing speed tests regulary returns figures as low as 7mb! When im paying for 30 or more!
on 28-10-2020 08:38 AM
Hi Court7719
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 26-10-2020 08:41 PM
Hi @Court7719 ,
Are you doing speed tests 'wired' or 'wireless', it is best to do them 'wired' to get accurate results.
Can you ensure that you have used the new cables and microfilter (if required) supplied with your router to connect your router to the phone socket.
Have you tried switching the router off for over 30 minutes, then when you switch it back on it will start a new 'session', this can sometimes help it reconnect at a better speed.
It would be worth going to the Service Centre to do a test on your phone line, this will indicate if there is currently a fault on your line. You can also access this from the ‘My Account’ site.
Then they will hopefully be able to respond to this post within a day or two.
