on 15-01-2022 05:19 PM
I'm on Fibre 65 package. The internet speed to router shows good but speed to device show as poor after speed tests. I was on live chat, they reset the router from their end and I cleared cache & cookies from my end, then the chat got terminated. My wifi signal is poor no matter where I position my router and no matter how many devices are connected.
Any advice on how I can improve my wifi signal would be greatly appreciated.
on 23-01-2022 04:40 PM
Aha, fair enough! 🙂
on 23-01-2022 04:39 PM
Hi @ferguson just something for my own interest as I too need a new adapter.
on 23-01-2022 04:38 PM
@KeithFrench ????
on 23-01-2022 04:26 PM
I've PM'd you Keith, but yes they were screenshots from my new adapter.
on 23-01-2022 04:04 PM
Hi @slwukuk
Can I ask you a quick question, please? The screenshots from the Realtek utility you included yesterday, were they from this new card or the original one? So many use the Realtek chipsets it can be difficult to know. To be certain please could you get me the output from the Windows command prompt by using this command:-
netsh wlan show interface
Then press the Enter key. Please can you paste the output or get a screenshot of it for me? Please feel free to PM it to me if you prefer.
on 23-01-2022 03:44 PM
You're very welcome.
on 23-01-2022 03:41 PM
The speed I get to my router is really good, I have no complaints with TalkTalk at all. People are too quick to slate anything that isn't going their way, when usually the problem is easily fixed when you know what you are doing, which I am thankful for this community for pointing me in the right direction. I understand stuff better at the end of this thread than I did when I first started it. Thanks again people 🐵 🐵 🐵
on 23-01-2022 03:31 PM
Hey @slwukuk keep at it! Different solutions work for different devices. At least we have established that your TalkTalk service is fundamentally sound and you have found a way to improve the wireless speed to your laptop.
on 23-01-2022 03:23 PM
That's right, I always did use it wired, up until one of the Powerline adapters failed, but I've read that Powerline adapters don't last forever.
on 23-01-2022 03:21 PM
Ethernet will always deliver the best performance for TVs & other audio-video equipment.
on 23-01-2022 03:19 PM
The TV does actually connect to the internet, it's just connected via wifi, the signal strength mustn't be strong enough as it won't even run any youtube videos. I'm just goona buy some more Powerline adapters eventually. Thanks for all the help given 🐵
on 23-01-2022 02:49 PM
Hi @slwukuk
@ferguson has said what I was about to, just use it in station mode for the laptop. Then deal with the TV's internet access as a separate issue, connecting that to the hub.
on 23-01-2022 02:31 PM
Yeah I've left it that way Ferguson, see I thought that it should be the newly created access point that I should be connecting to, to give me the increased speed. That's what I thought an access point would be. Anyway, Netflix can actually run via my firestick, but the Netflix app on my TV tends to get stuck when trying to view any film or series, I know if must be a wifi issue because when I used to connect via my my Powerline adapters the Netflix app would work fine. One in the pair of Powerline adapters has broken so I'm definitely gonna buy another set. But as for my new wifi usb adapter, it has more than doubled the wifi speed to my laptop 🐵 🐵 🐵
on 23-01-2022 02:08 PM
Leave the adapter in station mode. That will allow you to connect your laptop to the Hub at the best speed. Your TV should be connected directly to the Hub, not to the adapter. as access point.
on 23-01-2022 02:03 PM
Yeah mate I understand how it works, that's why it has me baffled. The TV connects to the access point, and it's the TV that is showing me that there is no internet. I can even test internet strength on the TV, but no internet when connect to the access point.
on 23-01-2022 01:54 PM
I have never used this facility, but I would imagine it should work like this.
When you are in Access Point mode, I don't think that the laptop will be connected to the internet itself, only the WiFi adapter is, as it is behaving like your router. It is broadcasting out a new network for your TV etc to connect to.
When in Station mode, the adapter is acting as an ordinary WiFi client & it connects to the router's WiFi to give the laptop internet access.
on 23-01-2022 01:44 PM
Kind of all sorted now Keith, via the new adapter I'm getting download speed of 60.5mbps which is great (for my laptop). I am having a bit of chew when I put the adapter to 'access point' as I want to connect my smart TV. I disable my onboard network card, and no internet, but it only says no internet when set as access point. I can disable my onboard network card when in 'station mode' and I get an internet connection.
on 23-01-2022 01:23 PM
Hi @slwukuk
How are you getting on now?
22-01-2022 10:50 PM - edited 22-01-2022 11:07 PM
Of course by splitting the SSiDs you are on the 5GHz band. However, that has half the range of the 2.4GHz band. It can be better to keep the network name identical ,& let the network adapter decide which is best. Then to find out which band you are connected to, just go to the command prompt and issue this command and press Enter afterwards:-
Then paste the output here or PM it to me & I will check it tomorrow afternoon.
on 22-01-2022 09:01 PM
Hi @slwukuk
I'll read through all of this & get back to you tomorrow afternoon.
