Poor speeds after upgrade to Fibre 65
perkinsleanne
Message 35 of 35
I recently upgraded to Fibre 65 from the Faster Fibre plan and have found that may speeds have not increased.
I have tried a router reset but it had no effect.
34 REPLIES 34
Message 21 of 35
Thanks @Debbie-TalkTalk, the router arrived today.
Wired test:
Download 56mbps
Upload 17mbps
Wireless:
Download 33mbps
Upload 17mbps
Message 22 of 35
Hi Leanne
Message 23 of 35
Yes please @Michelle-TalkTalk, hopefully that will help.
Message 24 of 35
Hi leanne,
Ok, would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
Message 25 of 35
@Michelle-TalkTalk no, I don't have either unfortunately.
Message 26 of 35
Hi leanne,
Thanks for running the different speed tests. The wired results also look low based upon the current sync speed. Do you have any powerline adapters? Do you have a different router that you can test with?
Message 27 of 35
@Michelle-TalkTalk tested today:
Speed to router 50mbps
Wired results:
Download 32mbps
Upload 12mbps
Wireless results:
Download 22mbps
Upload 11mbps
Message 28 of 35
Hi leanne,
Would it be possible to run a wired speed test please so we can compare the results? It will also help us to locate it this is solely related to the wireless connection. We can then offer additional advice on this.
Message 29 of 35
@Michelle-TalkTalk the tests were run wireless
Message 30 of 35
Hi leanne,
I've run a test on the line which hasn't detected a fault. Just to confirm, are you running the speed tests wired or wireless?
Message 31 of 35
Those figures look very odd. Download speed seems to be very slow compared to the upload speed. I always thought that the old "Faster Fibre" and new Fibre35 were limited to 10Mbps upload (perhaps someone else can confirm?), unless you had the "speed boost" applied in which case:
1, I would have expected you to have a faster download speed previously.
2, "Upgrading" to Fibre65 should actually have no effect on speeds as it is just the new name for "Faster Fibre with speed boost"
Message 32 of 35
Before: 33mbps & 18mbps
After: 23mbps & 18mbps
Was quoted 72.9mbps & 80mbps, with a guarantee of 67mbps.
Have switched the router off for over 30mins.
AllyM
Insightful One
Message 33 of 35
What speeds were you getting before the upgrade?
What predicted speed range and guaranteed minimum were you quoted when agreeing the new contract?
Did you switch the router off for a full 30 minutes before powering back on to ensure a new session was started at the cabinet equipment?
perkinsleanne
Message 34 of 35
Looking at other posts, not sure if a line reset is necessary or if I need a new router?
