Port Forwarding, ports closed
Groovy1
Message 7 of 7
I’m trying to open ports to view my cctv but they say they’re closed. I’ve checked them using my mobile data.
All was working ok until I changed to Fibre and used Talktalk sagemcom router.
Can someone tell me where I’ve gone wrong please.
6 REPLIES 6
Message 1 of 7
Hi @KeithFrench
Thank you for all your help, it’s working now.
The adapter I’d been using had disconnected from the internet and I hadn’t noticed. DOH!!!!!
A headache for 3 days and I’d missed an all important green light but thank you again for all your help.
Message 2 of 7
DHCP Reserved IP addresses won't change from the one that you are using, it just keeps you using that address. However, your CCTV should be setup to use a DHCP address in this case, not a static IP address. Using both DHCP & Static certainly causes problems with some routers. You should restart the CCTV after making these changes.
Doe the camera have more than one interface e.g. Ethernet & WiFi, if so are you using the correct one? When you test it, is the CCTV actually running with these ports open? That might sound daft, but not being there I have to try & cover off anything that might be the cause.
Message 3 of 7
Hi @KeithFrench
Funnily enough I’d tried to reserve the ip address today but it doesn’t seem to have made any difference.
I hope this is what you wanted a screenshot of.
I’m testing it on my mobile phone on data (not wifi) via www.yougetsignal.com using my external IP address.
Message 4 of 7
Well, there is nothing wrong with those rules, you might want to make the CCTV's IP address DHCP Reserved within the router.
Can you get me a screenshot or photo of the network configuration of the CCTV?
How are you testing it?
Message 5 of 7
Hi @KeithFrench
Many thanks, sorry I thought I had put a screenshot.
Message 6 of 7
Hi @Groovy1
No problem I can help you with this. Please can you tell me which TCP or UDP ports that you need to forward for your CCTV? Please can you include a screenshot of what you have setup on your router so far for port forwarding, so as I can check it for you?
