Port Forwarding
r_j_bass
Message 5 of 5
I am setting up an openvpn server on a raspberry pi and have configured Port Mapping for port 1194 to my server that has a static local ip address.
But it is not working. I have left the field for external ip address empty. I assume this will allow any external ip address b ut there is no documentation that I can find so this could be the issue.
I have also tried configuring a port mapping for ssh, external port 2200 mapping to port 22 on the same Rpi. Still no joy.
I have disabled the firewall. Still not working.
This should be an easy job and I can't figure out what I have missed.
Anyone got any advice?
Robin Bass
4 REPLIES 4
Message 1 of 5
Just glad to hear you got to the bottom of things.
Message 2 of 5
Just so you know, I did manage to 'fix' the issue myself. A bit embarrassing really, turns out the Raspberry Pi was not connected to the internet! After changing the network configurations to the correct ones, everything worked perfectly. What a surprise!
Mea culpa!
Robin Bass
Message 3 of 5
Hi @r_j_bass
@Michelle-TalkTalk has asked me to help you. First, please re-enabled the router's firewall, disabling it will not resolve the issue. Please can you confirm the make/model of router that you are using and tell if port 1194 is TCP or UDP. Then please get me a screenshot of the port mapping in the router so as I can check it for you. Does the Pi have its own firewall?
How are you testing this, via a web-based port checker such as:-
https://portchecker.co/
Message 4 of 5
@KeithFrench - Is this something that you would be able to offer any advice on?
