Port forwarding WiFi hub
Lspower
Message 3 of 3
Hi!
New here apologies if wrong place. I also tried a search but couldn't find exactly what I needed.
I'm looking to set up port forwarding for my Xbox one. I have the WiFi hub (sagecom).
I've done it before on older routers but I'm at a bit of a loss with this one as the layouts somewhat different.
The ports I need to open are as follows;
  • UDP: 88, 500, 3544, 4500
  • TCP & UDP: 3074
 I'd be extremely grateful for any help.
Chris-TalkTalk
Message 1 of 3
Hi Lspower,
Welcome to the Community. I can see that Keith has helped you with this, please let us know if you need any further assistance
Message 2 of 3
Port forwarding is easy on this router. Go into Advanced settings where you will see all of your devices listed. Click on the Xbox and reserve it's IP address (unless using a static address). Then click on the Port Forward tab & create one rule for each port.
If you still have problems, please send me screenshots from the port forwarding configuration.
