Port forwarding to fifa 22 Xbox one
Chrissymcm1
Message 7 of 7
Hello
I'm trying to port forward ports with the ipv4 mapping but I keep getting an error
Internal port 3074
External port start 3074
Ext port end 3074
What am I doing wrong I click apply then get an error
6 REPLIES 6
Message 1 of 7
I have just tested this on the Huawei & it worked first time:-
Please can you give details of the error message?
Message 2 of 7
Huawei
Message 3 of 7
Hi @Chrissymcm1
I have just tried TCP port 3074 on the Sagemcom & it worked fine. I will set up the Huawei & test that soon.
Message 4 of 7
There are two WiFi Hubs, one by Sagemcom & the other by Huawei, if you look at the label on the rear of the router, behind the pull up panel, it will identify which one you have.
I can't see any reason why port 3074 would gibe an error. Please can you include a screenshot of this? Is port 3074 TCP or UDP?
Message 5 of 7
Hello I have the new talk talk one that's on the homepage
Chris-TalkTalk
Message 6 of 7
Hi Chrissymcm1,
Which router do you have?
