Problem connecting devices to WiFi
catrionahm
Message 6 of 6
Hi, we are currently having issues connecting some devices over WiFi.
My laptop, TV, Alexa, Roku TV stick and both our phones connect no problem with fast connection speeds. However the Macbook and PS4 will no longer connect using WiFi and require ethernet connection. We have just got a Facebook Portal device and it is also not recognising the WiFi network despite the password being correct.
Does anyone have any advice for how to fix this? Thanks.
5 REPLIES 5
Message 1 of 6
No problem at all, it is just that allows me to tailor my reply to the router you have. Slow speed, intermittent dropouts, breaks in the signal, or no signal on some or all devices, might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
The TalkTalk Wi-Fi Hub is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
Append "5G" to the end of the network name of the "SSID" field. Then click "Apply".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
Having said that, there is another approach which can be better, which is to use Band Steering. This will automatically move any 5G compatible device connected to the 2.4G band to the 5GHz band. To use this facility on the Wi-Fi Hub, leave both network names identical.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Message 2 of 6
Sorry, Sagemcom.
Message 3 of 6
Sagemcom or Huawei, they are both different.
Message 4 of 6
It's a TalkTalk WiFi Hub. Thanks.
Message 5 of 6
It is most likely WiFi interference affecting the 2.4GHz band, with which I can help a lot. To enable me to help you, please can you specify the make/model of TalkTalk router that you are using?
