Problem connection
MartaB
Message 3 of 3
Hello. I have a question about the router. I currently have a huawei HG633 router and purchased a second hand Sagemcom Fast 5364-3T8 router. After connecting it to the network, it does not detect the Internet. What's the problem?
Message 1 of 3
Hi MartaB
Have you tried factory resetting the router using the pin hole reset for ten seconds?
Restore your router to factory settings
Skynet_TX
Message 2 of 3
Hi @MartaB,
What does the LED do on the router when you try to use it ?
Have you tried a factory reset of the router by holding in the reset switch on the back for over 10 seconds ?
If the router came with the cable and microfilter to connect it to the phone socket, are you using those ?
If you would like some help from the TalkTalk staff on this community you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
