on 02-04-2020 08:55 PM
I have the latest Sagem modem/router and have split the 5 and 2.4Ghz WiFi channels by renaming them. I try and keep the 5Ghz as free as possible as I use this for gaming. I have quite a number of home automated devices connected through the WiFi, possibly about 30 to 40, I have connected an older TalkTalk Huawei router to the main Sagem with its own SSID and connected as much as possible to that one. I have also separated the channels to 1 for the 2.4Ghz Sagem and 11 for the 2.4Ghz Huawei to minimise interference, they are also at different ends of the house.
so that’s my setup, everything works great apart from the 2.4Ghz SSID on the Sagem which lasts for a day then plays up. It appears to kick all the connected devices off, it is still visible but when I try and reconnect a device to it the device either fails to connect or states the password is wrong. If I reset the Sagem it works fine for a day. I am now resetting it each morning to avoid this issue.
i have recently performed a factory reset on the router but this didn’t help either. I read somewhere about TalkTalk doing some automated WiFi optimisation remotely and was wondering if this might be causing the issue. Can this be turned off to check?
otherwise I really like the router, however this issue has me wondering if a third party router might be worth investing in.
Any tips would be greatly appreciated.
on 20-04-2020 09:17 PM
I thought initially it may have, but the 2.4ghz is still having the same issue, hmmm very strange, any other ideas of what I could try?
on 08-04-2020 03:39 PM
Hi thunder_bolt,
OK, I've switched off optimisation, can you please monitor and let us know if there's any improvement
on 08-04-2020 02:32 PM
Thanks Chris, totally understand. If you could, I will stop resetting the router each morning and see how things go, if it turns out that it isn’t that we can always have it re-enabled I guess.
thanks.
on 08-04-2020 08:13 AM
Hi thunder_bolt,
Sorry for the delayed reply, we're doing our best in these unprecedented circumstances due to the Corona virus to answer everyone as quickly as possible.
We can try disabling wifi optimisation, to see if this is causing any problems, would you like to give this a try?
on 03-04-2020 10:56 AM
No problem, that should be updated now, no hurry, I appreciate you will be rather busy at this time, so no hurry.
on 03-04-2020 09:54 AM
Hi @thunder_bolt I have passed this onto the team to help with this. Before we can look into your account please can you add your home phone number to your Community Profile so we can locate your details. Please do not post any personal info on here as it’s public.
We’re working through a very large queue with a reduced support team at the moment, so we really appreciate your patience 😊
