Problems when online gaming
Dom_Hammonds
Message 8 of 8
I’ve been experiencing packet loss and ping spikes recently whilst online gaming. I’ve tested my connection and it’s performing fine. Could you look into this for me? It’s beginning to become unbearable to use as I can never get smooth gameplay anymore
Dom
7 REPLIES 7
Message 1 of 8
Hi Dom_Hammonds
It would be worth ruling this out.
The router is on its way, please allow 24-48hrs for this to arrive. Let us know how the connection compares with this router.
Message 2 of 8
If you think that it could be causing the issue? I’ve currently got a talk talk WiFi hub
Message 3 of 8
Hi Dom_Hammonds
Would you like me to send a different router for testing to see how the connection compares?
Message 4 of 8
Ok, thanks for checking that Debbie.
I only use a wired connection.
Message 5 of 8
Hi Dom_Hammonds
I've completed a line test which hasn't detected any faults and the line is in sync at 68.8mb.
How does the connection compare if you connect wired?
Message 6 of 8
All done,
Cheers
Skynet_TX
Message 7 of 8
Hi @Dom_Hammonds,
