Problems with F@st 5364 Router
ArthurW1
Message 13 of 13
My router stops working regularly - its white light stays on but there is no internet - either wifi or through ethernet cable. Turning it off and on again sorts it until the next time.
I am using a F@st 5364 router and Fibre 65.  It has been reset several times but this doesn't help.
I have now been told that I have too many devices connected.  I can count 15-20 - they don't use the Talk Talk wifi as I have a separate wifi system. I have read that the router is good for a small number of devices but also that it can cope with 50 devices.
Can anyone help me?
Is there a more suitable Talk talk router - is the Super Router better or worse?
ArthurW1
12 REPLIES 12
Message 1 of 13
Hi Arthur,
glad our team was able to help.
Message 2 of 13
Hi Debbie
Just to let you know that the new router is doing well - so I will return old one
Thanks again for your help - much better than all the times i phoned in for support
Best wishes
Arthur
Message 3 of 13
Hi Arthur
That's great news, thanks for letting us know 🙂
Message 4 of 13
Thanks Debbie
The new router arrived and is working well so far.  Assuming it keeps working,  OK, I'll send back the old one.
Thanks again for your help.
ArthurW1
Message 5 of 13
Hi Arthur
No problem 🙂
Message 6 of 13
Thanks Debbie
Much appreciated.
If the new router doesn't solve the problem I will contact you again through this Chat.
ArthurW1
Message 7 of 13
Hi Arthur
Yes that makes sense 🙂
I'm using the Huawei hub at the moment and I think it's a really good router.
I have ordered you a Huawei hub for testing and you should receive this within the next 24-48hrs.
We would need you to send the Sagemcom hub back using the pre paid returns bag (I've ordered)
At a later date, if you would prefer to use the Sagemcom hub again then I can send this out again and hopefully the firmware will then be available.
Message 8 of 13
Hi Debbie
Does that have the ability to cope with the traffic of my devices?  If so, maybe I should try it and then,  if it doesn't prove able to cope, revert to the present F@st 5364 Router once there is a Firmware update.
Does that make sense to you?
Arthur W1
Message 9 of 13
Hi ArthurW1
We do have new firmware coming soon for the Sagemcom router but I don't have a specific date that I can share as yet.
Would you like me to send you a Huawei WIFI hub?
Message 10 of 13
Thanks Debbie
I have updated my profile
It sounds as if i should hang-on for the firmware update unless there is a more suitable router available.
ArthurW1
Message 11 of 13
Hi ArthurW1
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 12 of 13
Hi @ArthurW1,
There is a known DNS related issue with this router that can cause symptoms very much like the ones you are seeing, so it maybe that you are suffering from that issue. There is a new version of firmware being tested at the moment that will hopefully resolve this, but it is not quite ready for release yet.
