on 12-05-2022 08:16 AM
Hi, currently experiencing issues with our internet, unsure of the specific issue but suspecting it's the router.
Is there anything that can be done to expedite this, a few days seems excessive and I'm assuming this is for an update on the situation rather than a resolution date.
Unfortunately, I don't have a spare router to try and isolate the issue.
Would appreciate if anyone can provide a bit more information on what's going on and what I can do to get this resolved as soon as possible.
on 12-05-2022 10:35 AM
OK thanks. I think we are probably as well trying another wifi hub so would you like me to send one to test with?
on 12-05-2022 10:28 AM
Yes the connection was fine and I have had this router for over 2-3 years
on 12-05-2022 09:10 AM
So was the connection initially OK with the wifi hub when it was sent as a replacement?
on 12-05-2022 09:05 AM
D-Link Model: DSL-3782
This was replaced with a TalkTalk WiFi Hub as this one was dropping Internet connection every few hours. Hence why this may not be a good test.
on 12-05-2022 09:00 AM
Thanks, what is the make and model number of the old router?
on 12-05-2022 08:38 AM
No issue on the line itself just the internet connection. I have plugged in another router and the same thing has occurred, however, it was an old TalkTalk router, which may not have been a good test.
on 12-05-2022 08:36 AM
OK thanks. Line test is passing but your router appears to be constantly reconnecting to the Internet. Are you experiencing any problems with your telephone service, any noise on the line?
on 12-05-2022 08:26 AM
All details have been updated.
on 12-05-2022 08:21 AM
Hi Menesh,
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
