Really fed up with this awful connection
ghera2711
Message 21 of 21
I have been with Talk Talk for almost a yera now. This connection is the worst I have ever had.
The router keeps disconnecting ever 5-10 minutes. I can't even watch Netflix.
I complained immediately after the router was installed, they have done some "checks" and everything was fine from their side. They sent a technician to "solve" it but nothing changed.
I am stuck with this terrible service for more than 1 year but I am seriously thinking of paying the fee and subscibe with a serious provider. Talk talk is the cheapest because it is the worst. I discourage everybody to subscribe for a contract with them. Really unsatisfied and fed up with it.
alessandro gherardi
20 REPLIES 20
Message 1 of 21
I can hardly make anything out from these screenshots, because they are way too small. If I download them & enlarge them, they are still too small & all the text is then out of focus. In future please take the screenshots with Acrylic maximised & upload them via the Photos button as "Large" images.
However, I think I can make out the problem even though, assuming you did highlight your SSID (network name) on the 2.4GHz channel view. Your suffering a lot of interference on channel 6, you need to reduce the channel bandwidth to "20MHz only", otherwise you will always get interference in this band & move to either channel 1 or 11 (see my guide on how to do this).
Message 2 of 21
Hi, tonight I didn't notice the usual issues but I have done the test anyway. Here are the results
Thank you
alessandro gherardi
Message 3 of 21
Thank you Keith,
I will do it as soon as go back home
regards
alessandro gherardi
Message 4 of 21
The whole point of this forum is that anyone can try & help anyone else, not just the TalkTalk OCEs. I am often asked by the OCEs to help on their behalf. I do not charge anything for my services at all, but I do need you to co-operate with what I ask.
Please see my attached guide on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide (no photos please they can be difficult to read as text can get out of focus when zoomed), from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
Message 5 of 21
Hi Keith,
clearly I need help, but since I pay £32 / month I expect TalkTalk to offer help, not a keen (and kind) customer. I asked for help 3-4 times to TalkTalk and the customer service is ridiculously poor. Eventually they sent a technician that just checked the network up to my building, while clearly the issue is the modem itself.
I am happy to accept your help Keith, even if it is not the way it should be.
Please let me know what you think I should do to fix this issue.
Thank you
alessandro gherardi
Message 6 of 21
Hi ghera2711
Keith can really help with WiFi issues if you follow his advice and work with him.  He has been solving these type of issues for many years and has a wealth of experience in this area.
Message 7 of 21
Please read the last two paragraphs of my post on 26-02-2019 11:02 AM and then again my post from 19-05-2019 11:54 AM.
I keep offering you help, but you never have said you want it.
Message 8 of 21
The stability of the WiFi is getting worse and worse. Yesterday I couldn’t manage to have 2-3 minute call on WhatsApp because the WiFi kept dropping all the time.
I am seriously thinking to cancel my contract and get a serious provider.
alessandro gherardi
Message 9 of 21
I am not surprised, if you had read the last two paragraphs of my last post, I did say it fixed nothing & that if you want my help, then let me know.
Message 10 of 21
this didn’t fix the issue.
I am now using a 20 mt cable crossing my corridor to use the wired network.
Awful. I can’t wait to change provider.
thank you
alessandro gherardi
Message 11 of 21
The HG633 is a dual-band router & offers both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and use the unique router password (see the label on the rear of the router at the top).
Go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
An alternative is to use band steering. This will automatically move any 5GHz capable device to the 5GHz band, providing better performance for the device & fewer devices are then subject to the interference on the 2.4GHz band. To enable this, first set both SSIDs to the exact same name. Then go to:-
Home Network > Wireless Settings > Enable Wireless Network Frequency Bands
Then put a tick against Enable Band steering.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Message 12 of 21
Hi ghera2711,
Thanks for letting us know. @KeithFrench - Would you be able to offer any more advice in regards to the wireless connection?
Message 13 of 21
After few months of test I can confidently say that wired connection is ok and WIFI is still awful on mobile devices.
Thank you
alessandro gherardi
Message 14 of 21
Hi ghera2711,
Ok thanks for the update and please let us know how you get on. If the wired connection is ok then we can focus on the wireless.
Message 15 of 21
Hi MIchelle,
the failure doesn't happen all the time. It is almost ocntinuous during the evening/night.
Other colleagues of you did the test during the day and didn't notice anything.
I will try with cabled newtork and let you knwo
alessandro gherardi
Message 16 of 21
Hi ghera2711,
I've run a test on the line which hasn't detected a fault and the sync speed looks consistent and the connection also looks stable. The router also has the latest version of firmware.
Would it be possible to connect wired for a short period of time to see how both the stability and speed compares and so we can confirm if this is related to the wireless connection?
Message 17 of 21
Done.
Thank you
alessandro gherardi
Message 18 of 21
1  - HUAWEI HG633, version H.1.01
2 - Some of the green lights go OFF and a red light starts blinking. I have to check which one does what if needed.
3 -  I don't use wilred connections, but PC, phone, ipad and TV get disconnected fromt he WIFI at the same time
Thank you
alessandro gherardi
Message 19 of 21
Hi ghera2711
In addition to Keith's questions, can you also add your home phone number to your Community Profile so we can look into this.
Message 20 of 21
1. What make/model of router do you have (if this is a TalkTalk router, these details will be on a label on the rear or underside of it) and what firmware version is it running?
2. What is the exact status of the lights on the front of the router when this happens?
3. If you have any wired connections, are they affected in the same way as wireless ones?
