Recently upgraded my fibre package and have sporadic speed issues since
Dave S1
Message 27 of 27
Hi, I upgraded from an older fibre package to Fibre 65 at the end of last month, but since swapping over to the new router, my internet has been very sporadic ranging anything from 0.9 mbps download (reminds me of the old dial up!) to around 47 mbps with uploads speeds of 5 to 7.2 mbps, this is the same for either a wifi or, a hard-wired connection. The sync speed   shown on the new router is over 50 mbps down and 6.75 up. It has shown higher speeds but this is a rough average. I have turned the router off twice over the last 9 days for 30 mins so I can basically work from home. This normally works for about 9 hours, then the connections goes up and down again.  I seem to be having to reset the internet connection frequently to get some sort of a workable connection.
When I plugged the old router back in, recheck the speeds etc all seems to be fine both on wifi and the hard-wired (40 mbps and 7.2 upload).
I have chatted to the live chat twice now who have acknowledged and seen the issues etc but until the ‘training period’ is completed, nothing much else they can do until after this time and all checks on the router and line all seems to be fine!
On looking at the chat forums I can see that some people have had their firmware upgraded to v1.06t which rectified their sporadic speed issues, so wondered if this may help me?
Any assistance or guidance would be very much appreciated.
Many thanks
Dave
26 REPLIES 26
Message 1 of 27
Hi Dave
No problem, please let us know how you get on.
Message 2 of 27
Thanks Debbie,
Appreciated, will see how things go.
Dave
Message 3 of 27
Hi Dave
The WIFI optimisation has now been switched off. Please let us know how the connection compares.
Message 4 of 27
Thanks Skynet, typical though speed has dropped to between 25 to 35 mbps download now! never mind, will wait.
Dave
Skynet_TX
Message 5 of 27
The Sagemcom has a feature called 'Wi-Fi Optimisation' that can cause this, basically the router will try to pick the best Wi-Fi channels even if you have specifically chosen channels yourself.
The staff here can switch Wi-Fi Optimisation off for you, it will then stay on whatever channels you set.
Message 6 of 27
Hi Chris,
Thought that I would give you an update, since the update etc on the router the internet has stabilized vastly, sync speed currently shows 44.8 down and 6.8 up. I did change the wifi channels on the router as the auto ones picked, due to other users in my vicinity using the same ones, but whilst watching iplayer it kept buffering, re checked speed etc and that seemed fine, but the channels reverted back to the heavily used ones. Changed them back yesterday and rechecked today and they have reverted back again!
Any ideas of how I can stop them changing?
Many thanks
Dave
Message 7 of 27
Message 8 of 27
Morning Chris,
Thank you for that, will see how this goes.
Dave
Message 9 of 27
OK, the firmware should be updated now, please let us know if there's any improvement
Message 10 of 27
Hi Dave,
I'll update your firmware now, it will take few minutes and the router may reconnect a couple of times
Message 11 of 27
Hi Chris,
Apologies, getting mixed up between them both, have now plugged the sagemcom one in so if you could have a look at that one please that would be fab.
Dave
Message 12 of 27
Hi Dave,
Thanks for that, sorry I thought you had the Sagemcom, your current router has the latest firmware version. We could try updating the Sagemcom to the latest firmware version, would you like to give this a try?
Message 13 of 27
Hi Chris
It is EchoLife DG8041W Home Gateway.
Many thanks
Dave
Message 14 of 27
Hi Dave,
Could you just confirm the  make and model number of the router that you currently have connected
Message 15 of 27
Hi Chris
Yes please go ahead, thank you
Dave
Message 16 of 27
OK thanks,
I can update your router firmware, I am OK doing this now, it should only take a few minutes?
Message 17 of 27
Hi Chris
Sync speeds have been fine, the download is better on the new router, the upload is hardly any difference between the 2 the throughput speeds as you say are very sporadic. To me it points towards an issue/setting on the router.
Currant speed test down 47 up 6 ping 12ms and jitter 1ms, sync on router is the same down 51.26 and up 6.66
Dave
Message 18 of 27
So it's the sync speed that drops, not just the throughput speeds (speed test results)?
Message 19 of 27
Hi Chris,
No issues with the line itself, dial tone clear and no drops on the internet if I make or receive calls.
Many thanks
Dave
Message 20 of 27
Are you experiencing any problems with your telephone service, any noise on the line?
