on 11-03-2022 05:28 PM
The line check in service centre finds a fault every few days and then it disappears, however fault returns.
My internet cuts out sometimes only for a split second it seems, sometimes for a few minutes.
In general in the last month it has been a less stable then it ever has.
on 01-04-2022 07:55 AM
Hi Sam
No problem 🙂
We will keep you updated.
on 01-04-2022 07:48 AM
thats great thank you for the update
Sam
on 01-04-2022 07:41 AM
Hi Sam
The fault has been assigned to a line engineer this morning so we should hopefully have additional updates later this afternoon.
on 31-03-2022 07:11 AM
Hi Sam
Apologies for this.
I have passed this straight over to Openreach to be investigated by a line engineer. We should receive further updates from Openreach within the next 48-72hrs.
I will continue to monitor for further updates.
on 31-03-2022 06:37 AM
Me again, recieved the package in less than 24 hours so thanks for that.
I have had the router in for the last day or so however still getting the same half speeds with some instability.
I have used the new router cables and filter from the test socket.
Also tested the speeds with just one wireless device and one wired device seperately on the new setup and still same speed.
Sam
on 28-03-2022 02:18 PM
Hi Sam2135
on 28-03-2022 02:10 PM
oh yes thats correct.
Many thanks
on 28-03-2022 01:29 PM
Hi Sam2135
I will send the router to the address linked to the telephone number in your Community Profile. Will this be ok?
on 28-03-2022 01:28 PM
you have my address? 😁
on 28-03-2022 01:26 PM
Yes can I try the Sagemcom Hub then please.
on 28-03-2022 12:16 PM
Hi Sam2135
I can send a Sagemcom hub or a Huawei WIFI hub and this will be boxed with new cables and filter.
on 28-03-2022 12:12 PM
hi,
I am up for trying a replacement router will it come boxed with new cable and filters?
Also will it be the same super router or whatever it is I have now?
Many Thanks for your help
on 28-03-2022 10:34 AM
Hi Sam2135
Would you like me to send a replacement router for testing first?
The next step following this will be an Openreach engineer visit to the property.
on 28-03-2022 10:31 AM
hi,
it is connected to the test socket and has been since yesterday.
thanks
on 28-03-2022 08:48 AM
Hi Sam2135
The line test is detecting a potential fault towards the property.
Is the router currently connected at the test socket?
on 26-03-2022 02:51 PM
OK cool, as I said let's see what the support team have to say.
on 26-03-2022 02:49 PM
no, we dont use the phone a lot but when it is used i havent noticed it effect the internet and its not that causing the disconnects that i get from what i can see.
Dial tone is normal and no noticable noise on the line.
Cheers
on 26-03-2022 02:46 PM
I should also have asked: are there any issues on the voice side at all, such as noise on the line?
on 26-03-2022 02:44 PM
OK, thanks for testing. Please await further advice from the support team when they are back online from Monday.
on 26-03-2022 02:42 PM
yes it does, thank you.
it has not impacted on the issue though unfortunately.
