Reduced broadband speed
Zendo2019
Message 5 of 5
Just need some advice 3 weeks ago my broadband has gone from around 60-70mb to 35mb just want someone to have look at router setting . Talk talk say line is fine but can anyone recommend what do do next p.s i have changed back to old router it made it worse so i went back to my own router coz my router is archer vr 900 thanks IMG_20190317_142632.jpg
4 REPLIES 4
Message 1 of 5
Hi Zendo2019,
Thanks for the update and please let us know if you need any assistance.
Message 2 of 5
Yes put my speed back to 60mb
Message 3 of 5
Hi Zendo, did that help?
Divsec
Message 4 of 5
Hi Zendo have you tried a 30 minute reboot this helps DLM to re-evaluate your line and often produces a positive results. Don't do it more than once a day as dlm will start to see the resartr as an error
