Regular disconnection of openreach g.fast modem
MikeS7
Message 20 of 20
There has been an intermittent connection fault with my internet since 20 April 2021. This date is when I changed to g.fast Fibre 150. I had no problem for many years before this.
The problem is that the internet is completely lost and there no connection. I can sometimes get it back up by switching the Openreach modem (openreach G.fast Modem Model MT992) on and off. Alternatively, I can also get it back up by unplugging the cable to the Openreach master socket. It also often comes back up without my involvement. The connection loss may occur several times a day. Note, when line goes down the openreach g.fast modem DSL and internet lights go out and the LAN and power lights stay on. Once I have switched the modem on and off the DSL light flashes slowly, then faster and is then solid. The internet light then comes on solid and the connection is restored (sometimes!)
The problem occurs with both the supplied TalkTalk router (TalkTalk Wi-Fil Hub Device Ver.: FAST 5364-3. T8) and my own TP-link router (TP-Link AC2600 Wireless Gifabit VDSL/ADSL Modem Router. Model Archer VR2600). My connection worked fine with the TP-Link router before the changeover to the Fibre 150, also when the internet goes down my internal network works fine. It therefore appears not to be a router problem.
I guess the problem is either with the Openreach modem or my new Fibre 150 line installation.
I have had no luck with the talktalk telephone help line or writing letters, so I hope someone here can help.
19 REPLIES 19
Message 1 of 20
Hi Mike,
Thank you for the update and please let us know how the connection compares over the next few weeks.
MikeS7
Message 2 of 20
Just to let you know the openreach engineer came yesterday. The line now appears to be working and has be up for neary 24 hours; which is a good sign. However, given my last experience, I think we need to wait a month or more before I am convinced everything is OK.
Mike
Message 3 of 20
MikeS7
Message 4 of 20
Thank you, I will let you know what happens.
Mike
Message 5 of 20
Hi Mike
The line test is now detecting a potential issue.
I have arranged the engineer visit for 12/11 AM (8am - 1pm)
MikeS7
Message 6 of 20
I just did a line test as the line was down for an unusual length of time (all night and not connecting) I got the following result
We suspect an issue with your broadband
We need to run a line test between our network and your home.
During the test, your broadband and phone line will temporarily disconnect.
In order for us to keep you updated, we need your mobile number
MikeS7
Message 7 of 20
I can confirm that the potential engineer charges are fine. I am not available tomorrow or the 17th November, all other dates in November (am or pm) are fine.
Mike
Message 8 of 20
Hi Mike
Please can you confirm potential engineer charges and provide your availability for this visit  AM and PM?
Engineer charges
MikeS7
Message 9 of 20
An engineer visit will be good, thank you.
Mike
Message 10 of 20
Hi Mike
Thanks for confirming this.
If you have tested with a different router and are still experiencing this fault then we will need to arrange another engineer visit.
Would you like me to arrange this visit?
MikeS7
Message 11 of 20
Nothing has changed at all and the line was down most of the night and early morning. I am afraid I have been through this before, there were many line checks from TalkTalk (usually via your telephone helpline people) and they did not detect a fault. In fact, I was surprised when you detected a fault. It was only when the engineer came that the line went back to normal for a few weeks.
I think this is a very unusual fault. As stated in my first post I have checked my system by using two different routers (see post for details). It is difficult to see how it can be me as the g.fast modem is independent of my system and I connect my router directly to it. The lights on the g.fast modem show a loss of the line and my router and interna network work fine (more details in my first post). If you have any ideas how I can do further checks then I can have a go.
Thanks for your help.
Mike
Message 12 of 20
Hi Mike
I'm so sorry to hear this.
I've completed another line test which hasn't detected any faults.
Has anything changed with your set up since the last engineer visit?
MikeS7
Message 13 of 20
Thank you for sending an Openreach engineer on 13th October. The engineer replaced my g.fast modem and checked the local cabinet. I am not sure exactly what he did in the cabinet. The line has worked fine until the 3rd November, but now exactly the same problem has started again.   The problem is as I reported in my first post, with no internet connection for long periods of time. Sometimes I can get it back by unplugging the cable to the Openreach master socket
I am not sure what the best course of action is, will another visit by the engineer fix it? Perhaps the best things is to put me back on my old connection and forget about the g.fast fibre to cabinet connection.
Message 14 of 20
Hi Mike
Thanks for confirming your details.
I have arranged the engineer visit for 13/10 AM (8am - 1pm)
Message 15 of 20
Hi Mike
Message 16 of 20
Yes, that would be great.
Thank you
Mike
Message 17 of 20
Hi Mike
Thank you.
I've completed a line test which has detected a potential fault towards the property and Openreach are requesting that we arrange an engineer visit.
Would you like me to arrange an engineer visit?
Message 18 of 20
I have now added these.
Mike
Message 19 of 20
Hi MikeS7
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
