Renewed Contract, Ungraded to Faster Boost Fibre but not getting anywhere near 66.8 Guaranteed Speed
RazzOne
Whizz Kid
Message 72 of 72
Hi OCE's
Can you look into my Fibre Speed please as I am not getting the Minimum Guaranteed Speed of 66.8Mbs.
I renewed my contract yesterday and got the Fibre Speed boost as a deal but speed tests reveal around 40Mbs Download and just under 9Mbs upload. I have switched my router off several times but still no difference. I have also checked the connection speed in the router admin but this is showing as: Upstream as 19239 (kbit/s) and Downstream as 61077 (kbit/s) but I certainly am not getting that internally.
I am performing the test on a Hard Wired PC with Ethernet Cable and just so you know I literally live across the street from the fibre cabinet and copper cabinet!
Hope to hear from you soon
Ry 🙂
71 REPLIES 71
Message 1 of 72
Hi Ry,
That's great news, thanks for letting us know 🙂
Message 2 of 72
Hi Guys
Just to let you OpenWorld Engineer has just left and the speed is up to:
Upstream line rate (kbit/s): 20000
Downstream line rate (kbit/s): 70355
Maximum upstream rate (kbit/s): 20132
Maximum downstream rate (kbit/s): 88040
So at the moment we are over the Minimum Guaranteed speed of 66.8.  So hopefully it stays above.
Thanks for everything we got there in the end. I will keep monitoring to ensure it stays above the minimum then report back probably for the last time.
Cheers
Ry
Message 3 of 72
Hi Ry
The engineer visit has been arranged for 06/06 PM (1pm - 6pm)
Message 4 of 72
Hi Ry
Thanks for the Private Message.
I have passed your availability over to our Network Team and I will post back on this thread to confirm the date and time of this visit.
Message 5 of 72
Hi Ry
Apologies for this.
Message 6 of 72
Hi Guys
I've tried new router and old router both connected to test socket and still it will not reach the minimum guaranteed 66.8 connection speed so I think its time for an engineers visit.
Cheers
Ry
Message 7 of 72
OK, thanks for the update
Message 8 of 72
Just a quick update guys.
My router is now downstairs connected to maintenance socket with below speeds. I will leave it for a few days then get beck in touch.
Upstream line rate (kbit/s): 17346
Downstream line rate (kbit/s): 61429
Maximum upstream rate (kbit/s): 17346
Maximum downstream rate (kbit/s): 88304
Cheers
Ry
Message 9 of 72
Message 10 of 72
Hi Chris
I think I will first move my router downstairs to improve the WIFI and see if this improved the sync speed because it will eliminate the extension into my cubbyhole. I am not holding my breath though because I have also tried the router plugged directly into the maintenance socket and sync speeds were the same.
Once I have moved my router I'll be back in touch.
Thanks for all your help
Cheers
Ry
Message 11 of 72
Hi RazzOne,
We can arrange an engineer visit to investigate further. Would you like us to do this? If you would then we'll just need to confirm some details with you
Message 12 of 72
Hi Michelle
Stability seems ok and performance as expected for the current 'slower' sync speed of:
Downstream line rate (kbit/s): 54707....... I was getting around 61500
Upstream line rate (kbit/s): 16808............ I was getting around 19000
This is significantly slower not slightly slower, wouldn't you agree?
The only thing I can see the engineers have done is somehow lower both MAX Upstream and Downstream which has in turn lowered the SYNC Speed.  So there action has had the opposite affect of what we were trying to achieve!
Also just to add, this was supposed to be an unattended visit by BT Openreach but i have not seen any engineers at either cabinet.
Cheers
Ry
Message 13 of 72
Hi RazzOne,
Our Network Team have advised that the line test is now clear and that the current sync speed is slightly below the guaranteed speed. How is the performance of the connection at the moment? The next step would be to arrange an engineer visit to investigate further.
Message 14 of 72
Hi RazzOne,
I've requested an update on the fault now. If you don't hear back by the end of today then please can you bump your thread and we can re-check this again for you.
Message 15 of 72
@Chris-TalkTalk wrote:
Our network team have confirmed that this has now been logged to Openreach as a non-appointed task, we should have an update within 72 hours so if you don't hear anything beforehand can you bump the thread on Monday and we'll check for updates
Hi Chris
Sorry I forgot yesterday to give you a bump so here is one today: BUMP 🙂
Message 16 of 72
Hi RazzOne,
Great, thank you 🙂
Message 17 of 72
That's great Chris I really appreciate it.
I will be back in touch on Monday
Message 18 of 72
Message 19 of 72
Thanks for the bump, I'm chasing this up with our network team, I'll let you know when I have an update
Message 20 of 72
Hi RazzOne,
I've raised this to our network team. Can you bump the thread tomorrow and we'll check for updates
Hi Chris
Just giving you a bump like you asked.
Please keep me updated
P.S. If the engineers foresee router reboots, is it possible they can avoid the following times?
06:30 - 06:40
09:30 - 09:40
12:30 - 12:40
15:30 - 15:40
18:30 - 18:40
21:30 - 21:40
00:30 - 00:40
If they cant avoid these times then I will disable my app that runs at those times
Cheers
Ry
