Replace talktalk router
craigroberts76
Message 3 of 3
I'm having issues with the supplied talktalk router and want to put my own Asus in place. I have fibre 150 so it uses a BT modem in between. I've connected the asus via the WAN port and i've tried various settings such as VDSL, PPOE etc but struggling to get it to get a connection. any ideas?
Message 1 of 3
I use an asus router and if you follow the setup wizzard it should give the option to auto set up without the need for a username etc.
bigkenny
Enlightened One
Message 2 of 3
have you had a look at these settings yet via this page https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
