Request for firmware upgrade for DSL-3782 Router
ConcernedCustomer
Message 19 of 19
Hi, I have been using a different (slower) router for a while now while waiting for this upgrade. I have seen other threads where people have had their routers firmware upgraded manually. I would like this for my router please.
18 REPLIES 18
Message 1 of 19
Hi ConcernedCustomer
No problem 🙂
Message 2 of 19
Thank you for your help really appreciate it
Message 3 of 19
Thank you 🙂 I have now updated your router firmware version.
Message 4 of 19
Hi, Had it turned off until now, Will be available for rest of day
Message 5 of 19
I'm still unable to connect to your router, could you try the pin hole reset on the new router please?
Message 6 of 19
I just got the router, it's still on 1.08t firmware
Message 7 of 19
The DSL3782 router is on its way, please allow 24-48hrs for this to arrive.
Let us know once this router is connected and we can check the firmware version.
Message 8 of 19
Yes please send a replacement
Message 9 of 19
Apologies I'm still unable to connect.
I can send a replacement DSL3782 if you would like me to arrange this?
It would also be worth checking that TR069 is enabled in the router settings?
Message 10 of 19
Okay I have reset, I am sure I did it correctly both times
Message 11 of 19
Could you try this again, ensuring you hold the reset button for a full ten seconds?
Message 12 of 19
Oh sorry, I have reset it now.
Message 13 of 19
I'm still unable to connect to your router, did you factory reset the router for ten seconds? (pin hole reset)
Message 14 of 19
Hi, I wasn't online until just now, I will be online for the rest of the day.
Message 15 of 19
Apologies for the delay.
I'm unable to connect to your router, please can you factory reset your router using the pin hole reset for ten seconds, I can then try and connect to your router again.
Message 16 of 19
The only one I know about is the WPA2 KRAK vulnerability that was sorted in this release (sorry forgot about that). The VPN fix is the main one though. I have asked one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Message 17 of 19
There is a security flaw that has been solved in the latest firmware. I also need to use a VPN which the old firmware has issues with
Message 18 of 19
What problems are you having with the DSL-3782, as the firmware only addresses one issue?
