Router being attacked ??
MrPuKKa
Message 5 of 5
Recently had a replacement router sent as firmware is unstable on previous make of router. I literally just logged into the router as webpages were not fully loading, a bit like previous issues. Router log shows external ips trying to log into the router continuously. I have recently read certain models of router are vulnerable to attack. Can somebody please help.
Trying to attach router log. log saved as txt file yet error appear txt not supported ???
The file type (.txt) is not supported. Valid file types are: pdf, doc, ppt, docx, pptx, xlsx, psd, gz, zip, svg, .txt.
Kind Regards
4 REPLIES 4
Message 1 of 5
No Problem 🙂
Message 2 of 5
@Karl-TalkTalk
Ahhh that explains it then. Hopefully I won't have any more issues. Thank you your assistance
Kind Regards
Message 3 of 5
ACS is our Router management platform, and the router will normally communicate to get the relevant settings for the router on first install.  It may have had an issue connecting with our platform, but I've checked and can communicate with the router. I've just updated the firmware on the router, so we if this is more stable with web pages.
MrPuKKa
Message 4 of 5
2021-05-05 16:09:39 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-05 22:42:17 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-05 22:59:57 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-05 23:38:34 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 00:28:35 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-06 00:28:35 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-05T23:28:35.060Z
2021-05-06 00:36:55 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 02:20:18 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 04:21:19 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 05:12:21 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 06:31:07 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 07:04:51 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 12:41:38 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 15:37:07 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 16:53:01 [Critical][Config-Log] Terminal:ACS(78.147.126.183),Result:Fail,Type:Authorization,:
2021-05-06 23:25:27 [Critical][Config-Log] Terminal:ACS(78.147.122.252),Result:Fail,Type:Authorization,:
2021-05-07 00:28:36 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-07 00:28:36 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-06T23:28:35.961Z
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset after being powered on, Terminal:OTHER
2021-05-07 14:59:13 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-05-07 14:59:13+00:00 DST], uptime is [75s].
2021-05-07 14:59:14 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-07 14:59:19 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-07T13:59:18.967Z
2021-05-07 23:06:30 [Critical][Config-Log] Terminal:ACS(78.147.122.252),Result:Fail,Type:Authorization,:
2021-05-08 13:04:25 [Critical][Config-Log] Terminal:ACS(78.147.123.34),Result:Fail,Type:Authorization,:
2021-05-08 14:36:13 [Critical][Config-Log] Terminal:ACS(78.147.123.34),Result:Fail,Type:Authorization,:
2021-05-08 14:59:19 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-08 14:59:19 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-08T13:59:19.499Z
2021-05-08 16:03:26 [Notice][Run-Log] SNTP has synchronized successfully, current time is [2021-05-08 16:03:26+00:00 DST], uptime is [72s].
2021-05-08 16:03:27 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-08 16:03:31 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-08T15:03:31.214Z
2021-05-08 18:02:33 [Critical][Config-Log] Terminal:ACS(92.29.162.89),Result:Fail,Type:Authorization,:
2021-05-09 00:55:26 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-09 02:15:28 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-09 02:41:42 [Critical][Config-Log] Terminal:ACS(92.29.250.120),Result:Fail,Type:Authorization,:
2021-05-09 04:55:48 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-09 05:37:55 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-09 07:11:49 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-09 07:53:34 [Critical][Config-Log] Terminal:ACS(92.29.70.202),Result:Fail,Type:Authorization,:
2021-05-09 09:03:22 [Critical][Config-Log] Terminal:ACS(92.29.189.34),Result:Fail,Type:Authorization,:
2021-05-09 09:14:11 [Critical][Config-Log] Terminal:ACS(92.29.162.89),Result:Fail,Type:Authorization,:
2021-05-09 10:47:19 [Critical][Config-Log] Terminal:ACS(92.29.189.34),Result:Fail,Type:Authorization,:
2021-05-09 16:03:31 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-09 16:03:32 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-09T15:03:31.965Z
2021-05-09 22:03:55 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-09 22:57:51 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 00:23:20 [Critical][Config-Log] Terminal:ACS(92.29.163.102),Result:Fail,Type:Authorization,:
2021-05-10 02:21:35 [Critical][Config-Log] Terminal:ACS(92.29.165.51),Result:Fail,Type:Authorization,:
2021-05-10 02:48:57 [Critical][Config-Log] Terminal:ACS(92.29.65.151),Result:Fail,Type:Authorization,:
2021-05-10 05:03:15 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 07:41:22 [Critical][Config-Log] Terminal:ACS(92.29.70.202),Result:Fail,Type:Authorization,:
2021-05-10 08:04:23 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 09:50:07 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 12:06:22 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 13:26:14 [Critical][Config-Log] Terminal:ACS(92.29.166.8),Result:Fail,Type:Authorization,:
2021-05-10 13:56:50 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 14:22:53 [Critical][Config-Log] Terminal:ACS(92.29.163.102),Result:Fail,Type:Authorization,:
2021-05-10 16:03:32 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-10 16:03:32 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-10T15:03:32.833Z
2021-05-10 16:03:55 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 16:42:39 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 17:34:00 [Critical][Config-Log] Terminal:ACS(92.29.250.116),Result:Fail,Type:Authorization,:
2021-05-10 17:51:08 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 19:45:23 [Critical][Config-Log] Terminal:ACS(92.29.70.202),Result:Fail,Type:Authorization,:
2021-05-10 20:23:47 [Critical][Config-Log] Terminal:ACS(92.29.162.70),Result:Fail,Type:Authorization,:
2021-05-10 20:50:59 [Critical][Config-Log] Terminal:ACS(92.29.250.116),Result:Fail,Type:Authorization,:
2021-05-10 20:59:04 [Critical][Config-Log] Terminal:ACS(92.29.162.70),Result:Fail,Type:Authorization,:
2021-05-10 21:05:17 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 22:40:04 [Critical][Config-Log] Terminal:ACS(92.29.162.70),Result:Fail,Type:Authorization,:
2021-05-10 23:33:38 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-10 23:45:05 [Critical][Config-Log] Terminal:ACS(92.29.189.34),Result:Fail,Type:Authorization,:
2021-05-11 01:23:22 [Critical][Config-Log] Terminal:ACS(92.29.250.120),Result:Fail,Type:Authorization,:
2021-05-11 01:50:12 [Critical][Config-Log] Terminal:ACS(92.29.189.34),Result:Fail,Type:Authorization,:
2021-05-11 02:02:07 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-11 02:47:06 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-11 05:00:41 [Critical][Config-Log] Terminal:ACS(92.29.161.195),Result:Fail,Type:Authorization,:
2021-05-11 05:10:05 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-11 05:50:29 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-11 06:49:41 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-11 06:58:35 [Critical][Config-Log] Terminal:ACS(92.29.161.195),Result:Fail,Type:Authorization,:
2021-05-11 08:11:47 [Critical][Config-Log] Terminal:ACS(92.29.161.195),Result:Fail,Type:Authorization,:
2021-05-11 09:07:30 [Critical][Config-Log] Terminal:ACS(92.29.189.34),Result:Fail,Type:Authorization,:
2021-05-11 09:50:50 [Critical][Config-Log] Terminal:ACS(92.29.161.105),Result:Fail,Type:Authorization,:
2021-05-11 10:22:52 [Critical][Config-Log] Terminal:ACS(92.29.161.195),Result:Fail,Type:Authorization,:
2021-05-11 10:43:38 [Critical][Config-Log] Terminal:ACS(92.29.250.120),Result:Fail,Type:Authorization,:
2021-05-11 11:11:10 [Critical][Config-Log] Terminal:ACS(92.29.161.195),Result:Fail,Type:Authorization,:
2021-05-11 16:03:33 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2021-05-11 16:03:33 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2021-05-11T15:03:33.762Z
2021-05-11 16:29:48 [Critical][Config-Log] Terminal:ACS(92.29.250.116),Result:Fail,Type:Authorization,:
2021-05-11 16:54:56 [Critical][Config-Log] Terminal:ACS(92.29.167.148),Result:Fail,Type:Authorization,:
2021-05-11 23:20:57 [Critical][Config-Log] Terminal:ACS(92.29.160.175),Result:Fail,Type:Authorization,:
2021-05-12 04:40:33 [Critical][Config-Log] Terminal:ACS(92.29.250.120),Result:Fail,Type:Authorization,:
2021-05-12 05:17:29 [Critical][Config-Log] Terminal:ACS(92.29.160.175),Result:Fail,Type:Authorization,:
2021-05-12 06:48:02 [Critical][Config-Log] Terminal:ACS(92.29.161.74),Result:Fail,Type:Authorization,:
2021-05-12 09:16:21 [Critical][Config-Log] Terminal:ACS(92.29.162.5),Result:Fail,Type:Authorization,:
2021-05-12 10:56:58 [Critical][Config-Log] Terminal:ACS(92.29.189.34),Result:Fail,Type:Authorization,:
2021-05-12 11:54:45 [Critical][Config-Log] Terminal:WEB(192.168.1.10),Result:Success,Type:Login,Username:admin
2021-05-12 12:03:39 [Critical][Config-Log] Terminal:WEB(192.168.1.10),Result:Success,Type:Logout,Username:admin
2021-05-12 12:16:50 [Critical][Config-Log] Terminal:WEB(192.168.1.10),Result:Success,Type:Login,Username:admin
