on 28-01-2022 09:53 AM
Morning
I have been having issues with my Fibre65 connection.
Since being connected I have noticed the router dropping connection, this has happened 3 times in the last 12 hours.
My guaranteed speed is 50mb+ and I am consistently getting only 30-39mb, something your service checker has flagged as poor.
I am also experiencing delays in reaching web services such as app data refresh and websites where the connection times out even though it states I am connected.
Line connection checks come back fine and there is no additional noise on the line. I have also powered down the router several times.
As a last note, when I check the logs in the router they are full of authentication errors and what appears to be router dropouts. (I am no expert in this tho)
Can these issues please be looked into as this is a poor quality connection.
on 02-02-2022 06:30 AM
Hi Chris4k1
on 01-02-2022 04:00 PM
Hi Debbie, yes please that would be of great help.
on 31-01-2022 07:39 AM
Hi Chris4k1
Would you like me to send you a different router for testing to see how the connection compares?
on 28-01-2022 03:56 PM
I have changed the channels of both the 2.4 and 5ghz networks. The 5ghz channel performs as expected, however as it appears the 2.4ghz channels are quite congested I can still only reach 32-34mb speed on this network. Any ideas how to improve this? Surely I should expect the same network speed on both 2.4ghz and 5ghz?
What is causing the router to reset the connection? This is not normal behaviour, I have not had this issue on any of my fibre connections to date.
on 28-01-2022 02:02 PM
Hi Chris4k1,
Sync speed is showing 75.2Mbps. The logs show one reconnection today, two yesterday, one on the 26th and one on the 25th. No other reconnections showing until the 17th. Also shows that all local wifi channels are congested
Do you have any devices connected to you router by Ethernet cable?
on 28-01-2022 12:32 PM
Hi Michelle,
I have done shut the router down for 30 minutes and the above is the result. What speed are you showing when you run the test? Also, do you agree that the router is dropping the wifi/connection? I can physically see my wifi drop out on my phone and the router lights start flashing indicating it is reconnecting.
on 28-01-2022 11:46 AM
Thanks for confirming this. Have you tried a few different wireless channels to see how this compares? I'd also recommend switching off the router for a full 30 minutes and then retesting the speed again as this will reset the current session and can often increase the speed.
on 28-01-2022 11:39 AM
Hi Michelle,
Thanks for the reply.
I am connected wirelessly when the issues happen, just like this morning and my phone disconnected from the wifi due to the router reconnecting or something like that.
on 28-01-2022 11:33 AM
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault and the connection looks stable and the sync speed looks consistent. Are you currently connected wired or wireless when you experience the instability and slow speeds?
